1978 - 1996 Big Bronco
Knock Sensor...
Old Jan 26, 2008 | 03:45 PM
My87Stang50's Avatar
My87Stang50
Wink Knock Sensor...
What happens when you swap motors and the motor you put in has no place for the knock sensor?
Took out a 302..put in a 351w in a 1994 Ford Bronco...
Old Jan 26, 2008 | 04:53 PM
blue beast's Avatar
blue beast
Ruh roh raggy!! Weld a nut that the KS fits into at about the same place as the original
and hope it is able to pick up the vibrations bad bad bad vibrations do do dooo!!
It is there to alter the timing events if say when it is 95* out you are towing your
boat up a big hill and your fuel is a bit old or not at the advertised octane. It is needed
especially if you are going to be beating on it or towing etc. figure out a way You may
need to play with a couple different spots before finding one that is right, hopefully you don't find out the hard way that it isn't in the right spot!!(burnt hole in piston)
Having a quiet exhaust will help you hear if it is knocking so either leave the exhaust
or find a cheap muffler to throw on it to keep it quiet until you get it dialed in. The KS
is a piezo transducer it is tuned to the frequency of the knock and it listens for it.
Old Jan 27, 2008 | 08:37 PM
wildjon300ci's Avatar
wildjon300ci
Not needed...351 came without one, 302H.O that Ford threw in the 'stangs didn't have one, and my truck's been running fine for a year without one. Just listen to the motor, it'll tell you what it wants.
Old Jan 28, 2008 | 12:10 PM
JRCF's Avatar
JRCF
I did the swap to a stang motor all I did was tape upi the wires for the KS and ziptie it in a safe place. All is well truck runs great without it.
ModifierMR
38
May 2, 2024 11:52 PM
tadatruck
Apr 22, 2018 08:50 PM
rock2610d
Modular V10 (6.8l)
30
Jul 8, 2016 07:54 PM
Joe7qb
Sep 29, 2005 10:00 AM
George
Oct 12, 1999 01:35 PM
