I pulled codes
Old Jan 26, 2008 | 03:33 PM
redneckgrl88's Avatar
redneckgrl88
I pulled codes
Hello again boys I bought the Ford code reader and pulled codes, and here is what I got:
KOEO self test:
52
84
Continuous memeory codes:
15
Can you help me understand them?
Oh, and my brake light is on when ebrake is off, and goes off when its engaged....whats up with that?
Thanks,
Charlene
Old Jan 26, 2008 | 03:43 PM
Skandocious's Avatar
Skandocious
52 - Power steering pressure switch always open or closed.
84 - EGR Vacuum Solenoid circuit failure.
15(CM) - EEC battery powered Keep Alive Memory (KAM) test failed.
Old Jan 26, 2008 | 03:47 PM
redneckgrl88
I read that in the book, I need help understanding them though.
Old Jan 26, 2008 | 03:48 PM
Towmanjbo's Avatar
Towmanjbo
Check your brake fluid level that might be why its on. As far as why it goes out with the E brake , uhhhh????? IDK.
Old Jan 27, 2008 | 11:10 AM
Conanski's Avatar
Conanski
52 - Power steering pressure switch always open or closed.. Either fluid is low or the switch is faulty.
84 - EGR Vacuum Solenoid circuit failure.. Check the EGR vacuum circuit, broken vacuum lines are common on these old trucks. If vacuum is OK the EGR solenoid may be bad.
15(CM) - EEC battery powered Keep Alive Memory (KAM) test failed... The computer is loosing battery power, check and/or replace ground wires on the computer harness and in the engine bay. May be a good idea to pull the computer and check the connector for corroded pins.
Old Jan 27, 2008 | 11:25 AM
wayneF250's Avatar
wayneF250
Charlene, Does the computer have a "chip". Reason I ask'ed, is because that maybe where the code "15" is comming from...
Old Jan 27, 2008 | 12:18 PM
mhg's Avatar
mhg
this site will help you with testing the sensors and actuators
www.fordfuelinjection.com
they have all the info for testing and descibing what they do
Old Jan 27, 2008 | 02:19 PM
Surge08's Avatar
Surge08
I had a code 84 it was the sensor on top of the egr replaced it and haven't had the code come back.
Old Jan 28, 2008 | 01:42 AM
redneckgrl88
I am not sure but I don't think so.
Old Jan 28, 2008 | 01:44 AM
redneckgrl88
Where is the switch?
Old Jan 28, 2008 | 01:46 AM
Surge08's Avatar
Surge08
If you don't know I guess since you are not sure the answer would be a no then. Like Conanski had said its prob a wiring issue.
Old Jan 28, 2008 | 01:47 AM
Surge08's Avatar
Surge08
P/S switch is mounted on the P/S hose above the steering box
Old Jan 28, 2008 | 01:50 AM
redneckgrl88
Thanks Chris
Old Jan 28, 2008 | 01:52 AM
Surge08's Avatar
Surge08
Like the Nick name.
Old Jan 28, 2008 | 01:53 AM
Surge08's Avatar
Surge08
No problem
