Distributor Removal
Old Jan 26, 2008 | 03:33 PM
Bouts21's Avatar
Bouts21
Distributor Removal
I haven't started the truck since May of 07, and I'm getting ready to bring it back on the road now. I'm going to change the oil and filter prior, and want to prime the oil pressure prior to starting. So, I'll be removing the distributor and turning the oil pump with the shaft till the pressure builds. Question I have is what are the chances of the pump shaft pulling out of the pump and coming out with the distributor, or worst case scenario falling into the oil pan?
Old Jan 26, 2008 | 04:31 PM
RJR99SS's Avatar
RJR99SS
It's a 400 right? The distributor drive has this little washer sort of thing pressed onto it down neat the bottom of the shaft. The shaft goes through a small hole in the block, and the washer wont let you pull it up through the hole. At least....thats how it worked with every m block i've seen.
Old Jan 27, 2008 | 12:46 PM
mark a.'s Avatar
mark a.
I'd just start it up & go.
1960fordf350
Jul 17, 2013 03:52 PM
jeff14346
Dec 28, 2011 06:46 PM
286merc
Aug 24, 2007 03:59 PM
LEckart
May 4, 2004 03:03 PM
Lifted ford
Oct 29, 2002 12:41 PM
