390 distributor questions
Heres what I have, freshly rebuilt 390, pressure primed on engine stand, got oil into upper end of engine. installed into truck, using DUI HEI disy, have autometer guages under dash, cranked engine over no oil pressure. Removed disy, pressure primed in truck have 60psi on guage. brought #1 to tdc apprx 18-20 degrees on balancer, droped in the disy, rotated oil pump shaft prior to install of disy. rubber seal on disy sits into the intake apprx 1/8 inch, seems like disy is not droping down enough to enguage oil pump drive shaft. when I installed I had engine upside down, installed ARP one piece drive shaft in with that goofy washer facing towards top of motor, then installed oil pump. looking down into engine with dissy out I can see the top of drive shaft, lower portion of disy shaft hangs down below dist gear appr 1/2 inch, should be plenty to enguage oil pump drive shaft.
Thanks for any ideas and or suggetions
Jeff
when I had the disy out, I have another ford drive shaft, it slides into disy but it is a snug fit. When I pressure primed motor I used a 1/4 drive extension and installed 1/4 socket, had to grind on socket to get it to fit into the block.
Just reviewing on the internet, found an artical on a disy swap in a galaxie from oem to MSD, when going back in, the drive shaft would not stay centered, they used a dab of grease to hold shaft centered and then stabed disy
Any other cool ideas to try or check??
Jeff
