Sponsored by: Real Truck
Rear end Vibration?
Old Jan 26, 2008 | 02:44 PM
simoniztexas's Avatar
simoniztexas
Question Rear end Vibration?
I have an 06' 6.0 Superduty. When I take off from a stop and turn or take off pulling a load I get a vibration that feels like it is in the rear end. It stops as soon as I get moving at about 3 mph. It is usually not to bad but when I was pulling the trailer with a load it was pretty ruff. It doesn't do it when taking off from a stop and going straight.
Can anyone help me with this?
Thanks,
Chris
Old Jan 26, 2008 | 03:59 PM
rwilimo's Avatar
rwilimo
Sounds like clutch chatter in a posi rear. If you do have a posi, adding friction modifier will likely fix it.
Old Jan 26, 2008 | 08:58 PM
1toptech's Avatar
1toptech
Unhappy
Change the read end fluid and use to bottles of friction modifier, ford part #XL-3. If that doesn't cure it, you will need the cluthes replaced.
Old Jan 26, 2008 | 09:01 PM
ford390gashog's Avatar
ford390gashog
Yep change the rear fluid and add 2 bottles of modifier. Or others like myself have used Mobil 1 and Royal Purple with great luck. No extra modifier needed. Or worst case the clutches will have to be replaced.
Old Jan 26, 2008 | 09:32 PM
redford's Avatar
redford
FTE Leadership Emeritus
There is a TSB on this:
https://www.ford-trucks.com/tsb/full...hp?tsb=05-17-6
TSB
05-17-6 DRIVE-AWAY SHUDDER OR VIBRATION
Publication Date: August 16, 2005
FORD: 1999-2006 F-Super Duty
This article supersedes TSB 04-22-7 to update the vehicle model years.
ISSUE:
Some 1999-2006 F-Super Duty vehicles may exhibit excessive drive-away shudder or vibration, under moderate to heavy acceleration from a stop. This may be due to driveline angle.
ACTION:
Shim the center carrier bracket downward to correct the condition. Refer to the following Service Procedure.
SERVICE PROCEDURE
When shimming the center carrier bracket, a maximum of three (3) 1/4" shims may be used (EOTZ-4A209-A). When refastening the carrier bracket use bolt (56564-S2). A 7/16 x 14 grade 5 bolt may be substituted providing that it extends at least three (3) threads past the nut. Use Motorcraft Threadlock 262 (TA-26), and torque bolts to 46 lb-ft (62 N-m).
NOTE: IF THE VEHICLE IS NORMALLY LOADED, ROAD TESTS WILL NEED TO BE PERFORMED WITH THE VEHICLE LOADED.
Before beginning the repair, road test the vehicle to gain a feel for the harshness of the shudder/vibration.
Install one (1) shim, (DO NOT use Threadlock on the bolts at this point), re-road test vehicle.
If condition is corrected, apply Threadlock and torque bolts as directed above.
If condition is not corrected, re-perform Step 2 (to a maximum of three (3) shims) and reevaluate vehicle.
NOTE: IF THE CONDITION IS STILL NOT CORRECTED AFTER INSTALLING A MAXIMUM OF THREE (3) SHIMS, REFER TO WORKSHOP MANUAL SECTION 205-00 FOR FURTHER DIAGNOSTICS.
PART NUMBER PART NAME
EOTZ-4A209-A Shim
56564-S2 Bolt
TA-26 Threadlock 262 Motorcraft
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
051706A 1999-2006 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair (Includes Time To Raise Vehicle And Install Threadlock) 1.2 Hrs.
051706B 1999-2006 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair Condition Still Exists, Install A Second Shim And Road Test (Includes Time To Raise Vehicle And Install Threadlock) 1.7 Hrs.
051706C 1999-2006 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair, Install A Second Shim And Road Test Condition Still Exists, Install A Third Shim And Road Test (Includes Time To Raise Vehicle And Install Threadlock) 2.2 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
4A209 42
Old Jan 27, 2008 | 04:13 PM
simoniztexas
Thanks guys thats a big help. I'll try changing the fluid. Now I still have the balance of the power train warranty. Will this be covered under this warranty?
Thanks,
Chris
Old Jan 27, 2008 | 07:17 PM
redford's Avatar
redford
Yes, call your dealership and advise them you would like your vehicle fixed per TSB 05-17-6.
Old Jan 27, 2008 | 08:17 PM
simoniztexas
Thats great. Thank you very much for your help.
Chris
bebeard
Feb 9, 2014 11:49 AM
redwood
1997 - 2003 F150
Dec 31, 2013 02:39 PM
newboot06
Feb 18, 2011 03:18 PM
jsmorris
Jul 16, 2009 08:45 AM
chris60
Oct 18, 2006 07:13 PM
