Best Water Temp For A Flathead?
Old Jan 26, 2008 | 01:39 PM
frb9883's Avatar
frb9883
I have a recently rebuilt flathead (8BA) in a '49 F1. The thermostats are 180 degrees. I have a electric fan controlled by a 180 degree thermo switch. Once the engine reaches 180 the fan comes on and the temp drops to 170 and stays there. I think this is too low. What is the optimum temp. for a flathead? To raise the temp I can install a fan switch that closes at a higher temp or change the thermostats.
Frank
Old Jan 26, 2008 | 01:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You're right, your settings are too low. The fan should come on at about 200. Flatties will sludge up if run cool.
Old Jan 26, 2008 | 02:03 PM
frb9883's Avatar
frb9883
Thanks. I will replace the fan switch. Also, you helped me in the past try to solve my oil pressure problems. The problem was easily solved. I was running an oil filter plumbed just the way the original Ford system was set up except I was using a Fram PH8. It did not provide enough restriction. I plugged the galley from the block and now have 50 PSI at idle at 170 degrees. I also copied your PCV valve set up using a Toyotoa PCV valve. Once I learn how to add photos to these postings I'll send you a picture.
Thanks again for the ideas.
Frank
Old Jan 26, 2008 | 02:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Are you sure your fan switch isn't adjustable? Most are.
I'd like to see your PCV setup, does the Toyota PCV valve fit tight in the grommet?
Old Jan 26, 2008 | 02:15 PM
frb9883's Avatar
frb9883
The switch is not adjustable. Stamped 180 on the body. I have to drain the coolant anyway as I'm replaceing the temp gauge with an Autometer. I'll make both changes at once.
PCV...Yes. It was originally a compression plug I got from Flathead Jack to plug the road tube hole. I stripped compression hardware and had to bore it a little. The valve fits very tightly.
Old Jan 26, 2008 | 03:14 PM
galaxie641's Avatar
galaxie641
Did you mount the Efan to the stock radiator? I am planning on running one but haven't looked into the radiator size or fan size yet. Also what size fan did you use?
Old Jan 26, 2008 | 10:08 PM
frb9883's Avatar
frb9883
Yes. I mounted it directly on the stock radiator. I bought it through Sacramento Vintage Ford. The fan is mounted in molded plastic. It was made by Cooling Components. It was an easy install.
Frak
51f1truck
34
Sep 11, 2019 01:52 PM
reed1951
29
Jun 27, 2018 07:50 PM
Blackwaterforge
15
Jul 14, 2010 10:04 AM
serving_time
Sep 14, 2003 02:53 AM
