Sponsored by: Real Truck
Chipping a 6 liter
Old Jan 26, 2008 | 10:40 AM
Flat8's Avatar
Flat8
Question Chipping a 6 liter
Thinking about putting a chip, larger exhaust, and cool air induction on my '04 6 liter. Any pro's or con's when doing a lot of heavy towing. This is a crewcab dually F350 with a rear air ride suspension already put on for leveling and stability.
Old Jan 26, 2008 | 10:49 AM
DCSpecial's Avatar
DCSpecial
Modded (i.e. programmer/module installed) are known to have head gasket/head bolt issues over time.
Not saying it's a guarantee, just that it's common.
A larger exhaust and cool air intake will help keep EGTs lower , especially if you add a programmer.
Be sure to run gauges if you add anything like a programmer/tuner on it.
Me personally, I tow heavy and rely on my 07 for work (approx. 2250miles per month) so I'm very hesitant about adding a tuner to it. Already have a cat-back exhaust installed and an intake that I might install.
Just my $.02
Old Jan 26, 2008 | 12:23 PM
UGA33's Avatar
UGA33
Head over to the 6.0L Diesel forum and do some research on tuners and chips. The 6L doesnt do well with the Edge, Bullydog, Banks...etc. The only thing i recommend and you will find out from your research is that an SCT w/ custom tuning is the way to go. Its a thousand times better for your truck and costs half the price of the others. Hope this helps
Old Jan 26, 2008 | 09:12 PM
1toptech's Avatar
1toptech
Sorry, but 6.0L doesn't do well on it's own. They are prone to head gasket failure. Torque to yield head bolts on a turbo diesel? What were the engineers thinking? If you chip it you are just uping your chances of major problems.
Old Jan 26, 2008 | 09:19 PM
fastfresh's Avatar
fastfresh
Don't do it unless you ready to get ARP studs (the chip turns these 6.0 s into granades) My brother put an airaid cold air system on his and then the techs at ford told him that it damaged his turbo and some sensor.
Old Jan 26, 2008 | 09:20 PM
fastfresh's Avatar
fastfresh
Hey my advise is to leave well enough alone......
Old Jan 27, 2008 | 02:57 PM
Flat8's Avatar
Flat8
Thank you for the input on the chip advise. For now I think I will well enough alone from what I've been hearing.
Old Jan 27, 2008 | 05:39 PM
tex25025's Avatar
tex25025
Rather or not you do decide to do the tuner later on, I would suggest atleast doing the gauges, particularly if you tow alot(as I do) and especially if your using an auto tranny as well. I would suggest custom tuning, however, what alot of people haven't mentioned yet, is that you can get programs that would help you in towing(or just for regular driving or various other conditions as well) and not affect hp or tq at all. This applies more to people with auto trannies as you can adjust shifting(both firmness and shift points). Just more food for thought as most people believe that tuners are limited in what they can do, but with custom tunes just about anything is possible. Now if you go off the shelf then your stuck with what they give you.
freebird63
Computer Chips & Tuners
Feb 28, 2014 10:15 AM
Wynnscapes
Dec 7, 2005 12:16 PM
BigBadBob
Jan 11, 2005 03:20 PM
jolly green giant
1997 - 2003 F150
Jan 28, 2004 11:59 PM
mild 02
3.8 & 4.2L V6
Sep 3, 2002 12:12 PM
