WTF did I break??!!!!!
Old Jan 26, 2008 | 01:31 AM
ford71's Avatar
ford71
I got my rwd f-100 stuck on some ice (damn wisconsin winters) so, being the retard I am I rev'd the **** out of it until I got back onto plowed road. after going for a few feet I noticed that my AOD tranny wouldn't shift outta first and the fluid smelled burnt. I don't know squat about transmissions so if anybody has some ideas about what i broke and how to fix it it would really help
Old Jan 26, 2008 | 01:42 AM
randall2051's Avatar
randall2051
take it to a trans shop your best bet
Old Jan 26, 2008 | 05:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If your 1971 F100 has AOD, it was swapped in. No AOD's till 1983 on F Series trucks.
I hate to tell you this, but you fried the transmission.
Figure on $1000 - $1500 at the very least for an overhaul.
AOD: HEAT is its mortal enemy.
Two things are important if you want to keep your AOD in one piece.
First: STAY OUT of overdrive in heavy stop and go traffic...the constant shifting up/down between drive and overdrive fries the transmission. It doesn't take too long for this to occur, either.
Second: Install the largest external transmission cooler you can find.
Old Jan 26, 2008 | 12:17 PM
ford71's Avatar
ford71
AOD is outta an 86 f-150
I have a 351m w/ a c-6 tranny i was gonna put in this spring, guess its going in a little sooner than i thought
Old Jan 26, 2008 | 01:46 PM
BobbyFord's Avatar
BobbyFord
AOD's are easy to overhaul but you need a lip-seal protector set. Ford recommends not to select the overdrive mode unless you are going to be driving at sustained speeds above 45 mph.
Old Jan 26, 2008 | 01:51 PM
bmuhlbach's Avatar
bmuhlbach
does your tran have a modulater.i had a c4 went out or vacuum line broke it would not shift out of first but when manually put in second it shifted to second.
Old Jan 26, 2008 | 01:58 PM
BobbyFord's Avatar
BobbyFord
AOD does not have a modulator.
JB78f150
Oct 24, 2012 12:10 AM
arrowheadfred
Feb 9, 2011 08:50 PM
MTDewX
Mar 19, 2010 10:40 AM
ponch37300
Nov 7, 2008 12:53 AM
blkbeast
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 15, 2008 03:51 PM
