Electrical prob
Old Jan 25, 2008 | 09:38 PM
magusjinx's Avatar
magusjinx
Question Electrical prob
A new problem raised its head today ... I drove to friends house 2 miles away ... an hour later the batteries were dead when I tried to restart to come home ... Charged them up for an hour ... Got home and they were dead again upon trying to restart ... Batts and alt are about 2 years old ...
Old Jan 25, 2008 | 10:06 PM
Franklin2's Avatar
Franklin2
Get the engine running, and check the voltage on the batteries. It should be around 14 volts. If it's 12 or less, your charging system is not working.
Old Jan 26, 2008 | 06:17 AM
PLC7.3's Avatar
PLC7.3
This is on your 86 F250.......did you have any dash light for charging problem. I would think possibly the voltage regulator..... should be getting about 14.5V of a charge.
Old Jan 26, 2008 | 08:34 PM
magusjinx's Avatar
magusjinx
Everything on the dash showed good ... But then I might not have paid as much attention as I should have ... Brain cells are getting olde ...
Old Jan 26, 2008 | 08:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The 86 ammeter is just to balance the gauges in the dash.
Mine has never moved since the day it was new.
Inspect the passenger side battery terminal and the wires going in and out of the terminal.
If the insulation is brittle, looks discolored like it was hot or you see corrosion in the wire conductor, you need a new positive cable.
All the electricity for the truck goes through that clamp, start, charge and cab power.
Old Feb 9, 2008 | 07:59 PM
Slopetruck's Avatar
Slopetruck
Hi, my batteries have been getting drained as well and am getting about 12.6 at the battery with the truck running. Is that pointing towards a alternator problem or something else?
Old Feb 10, 2008 | 01:02 AM
Dave Sponaugle
See if you can get the meter leads on the alternator output stud.
Check the voltage before you start the engine, then again after it is running.
Corrosion in the passenger side battery terminal can keep the charge from reaching the battery and the battery voltage from the starter.
Another option is have the charging system checked at a local part house.
Old Mar 9, 2008 | 01:13 PM
magusjinx's Avatar
magusjinx
WOO HOO ... Voltage regulator and a loose ground wire ... Next stop, relocate the batts to behind the cab and add 2 more ... That will make room under the hood for another alternator ...
farmerwill
May 6, 2012 05:24 PM
Coastie6
18
Nov 1, 2008 08:47 PM
prsmith
Electrical Systems/Wiring
Aug 20, 2008 07:42 PM
Inksma
Jul 26, 2006 09:18 AM
burritoman
21
Sep 27, 2004 06:47 PM
