Gears Question
Old Jan 25, 2008 | 08:29 PM
Dieselguy89's Avatar
Dieselguy89
Question Gears Question
I have a 92 f250 with a 7.3L with a auto electric overdrive don't know wat type.
And I want to know wat kind of gears I have. How can I check ?
also can I change the gears from a gasser what choices do I have
I don't do much trailor pulling just looking for better Gas millage, I do alot of highway driving
Old Jan 25, 2008 | 08:59 PM
David85's Avatar
David85
There are a few ways to figure this out.
You can take the axle code of the door tag and some one here can decode it.
or
Post your tach readings at say, 60 mph, and again we can help you figure it out (also need tire size)
or
This is the messiest way, but the most reliable. Take the differential cover off and count the number of teeth on the ring gear and the pinion gear. Then divide the number of teeth on the ring gear by the number on the pinion, round the result to 2 decimal places, and thats your gear ratio.
Old Jan 26, 2008 | 01:06 PM
archangel's Avatar
archangel
or
or
Why not just tell him to read the tag on the axle cover?
And 3.55:1 is the tallest they offered as far as I know.
Old Jan 26, 2008 | 05:03 PM
Franklin2's Avatar
Franklin2
I tell people that all the time, but there seems to be a tag bandit or something. They all go look and the tag is gone. I don't know why mechanics can't put the tags back on.
I redid a 351c and it must have been completely stock with no work done to it, because near the coil on top of the engine was a metal tag that told the year an everything. When I hopped it up with a aluminum manifold, etc. I put that tag right back on under that bolt. I thought someone someday may appreciate knowing what engine they had.
Old Jan 26, 2008 | 06:02 PM
David85's Avatar
David85
.....or they rust away, or the gears may have already been swapped, so even if the tag is still there, it could be lying. Which is why I said the most reliable way is to actually count the teeth on the gears.
Old Jan 26, 2008 | 06:22 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Mine are gone.
When I had the differential open I tried to save the tag.
But it was so rusty it fell apart.
Old Jan 26, 2008 | 08:01 PM
Dieselguy89
my axe code in the door is "35" and on the tag wat I can make out "v1290 10 10 22a08"
