I Want Quiet!!!
Old Jan 25, 2008 | 06:37 PM
bazzman1953's Avatar
bazzman1953
Arrow I Want Quiet!!!
Ahem, now that I have everyones attention...
I've read different threads on mufflers and exhaust, but none seem to cover my need, and that's for quiet.
I use my machine offroad for hunting, so I need to creep into and out of the woods with as little sound as possible. Any ideas on what I need in the way of exhaust/mufflers to use?
94 B-4000 4x4 M5OD Xcab
Old Jan 25, 2008 | 06:47 PM
powerstroke6ltr's Avatar
powerstroke6ltr
I would say stock would probaly be the quietest...
Old Jan 25, 2008 | 06:48 PM
Alon@ModBargains's Avatar
Alon@ModBargains
I agree. Anything aftermarket will be louder than stock
Old Jan 25, 2008 | 07:15 PM
bazzman1953
I can't help but wonder, though. Vehicals like the edge ect. aren't aimed at someone with my lust for the quietest machine I can achieve. If I have to install 2 mufflers on it, I might. I wonder if my mileage will take much of a hit doing so as it is also my daily driver?
Old Jan 25, 2008 | 07:43 PM
RangerPilot's Avatar
RangerPilot
Mileage doesn't usually get affected much by exhaust changes (unless you chop it).
Use a stock muffler, a resonator, and as much pipe as humanly possible. Even if you have to do some retarded bends, extend that pipe! That'll outta make as noticable a difference as you can expect to see...err...hear.
Old Jan 25, 2008 | 07:47 PM
G2IC_Wraith's Avatar
G2IC_Wraith
You could also use 2 or more resonators if space permits. They do a pretty good job of keeping the db down.
Old Jan 25, 2008 | 08:21 PM
RangerPilot
Lot harder to "sneak" in a manual, too, IMHO.
Old Jan 25, 2008 | 08:35 PM
bazzman1953
True, the a4ld was a lot quieter on my old '86, but I had to buy that truck, and this one was free, thanks to my son. 2nd gear is pretty quiet though, even in 4wd idleing through the woods. The exhaust is louder than the drivetrain.
More pipe? how about a 'y' with dual mufflers?
Old Jan 25, 2008 | 08:48 PM
scottie2hottie's Avatar
scottie2hottie
I think your best bet is to keep single exhaust, get a big f-ing muffler on there(like a stock one from an older V8 truck, new they are like $40) and throw a resonator on after that. If that don't quiet you down nothing will!
Old Jan 25, 2008 | 08:57 PM
bazzman1953
My wife can usually keep me VERY quiet, lol.
Old Jan 26, 2008 | 11:33 AM
RangerPilot
A muffler from a Super Duty or a Silverado would work nicely. Both have huge stock mufflers.
And one small thing you can think to do is to run the pipe so it exits on the opposite side of where your hunting grounds are...I know that sounds minute and insignificant, but every little bit helps. Personally, I'd get a muffler from a SD/Silverado, put dual resonators behind it, then wrap the pipe back and forth in a few S-curves under the bed, then split it down to two 1.5" pipes and run them out whichever side faces away from the area (in my case, the driver's side when I'm driving up to the deer stand).
Old Jan 26, 2008 | 06:21 PM
V-10 runner's Avatar
V-10 runner
Or maybe try a turf muffler,i can remember working at a golf course years ago
and all the equipment we used had them. Even the mowing tractors.
Old Jan 26, 2008 | 09:37 PM
Level2's Avatar
Level2
Try a Walker quiet flow muffler.
