Sponsored by: Real Truck
new need some help.
Old Feb 1, 2008 | 05:25 PM
  #31
slowcoupe's Avatar
slowcoupe
thats what i have been reading. the only problem is the earlier 6.0s im trying to stay away from since the last 3 have been crappers(by oasis). haha ive looked at 2 7.3s now and the oasis is clean and they both pull hard. the one ilooked at today was a 02 7.3 350 long bed crew cab. very mean looking with only 64,000 on the clock.
Old Feb 1, 2008 | 05:32 PM
  #32
swann79's Avatar
swann79
wow that's awesome for a 7.3... not many of those left. Sounds like a keeper to me!
Old Feb 1, 2008 | 05:40 PM
  #33
msgtg's Avatar
msgtg
Here's another word of advice....not that I'm shooing you away from that 7.3....read about 'lot-rot'.
This is a condition where a turbocharged truck sits more than it's driven. Corrosion begins to become a problem for the turbo. They have been known to clog up and then someones gotta tear it down and clean it up.
I would be a little wary of an older truck with not many miles on it. Again, I'm not trying to scare you away from that truck...just something else to be aware of.
Joe
Old Feb 1, 2008 | 05:46 PM
  #34
swann79's Avatar
swann79
msgtg - is there some easy way to look for that? Some way to "clean it up"? Just curious... Obviously I have little diesel experience.
Old Feb 1, 2008 | 06:02 PM
  #35
slowcoupe's Avatar
slowcoupe
yeh like how would i be able to tell if there is anything worng like that? the truck was very great and pulled hard for a stock 350. the modded 250 i took for s pin was very nice but this one was comparible. is cleaning the turbo vanes something a household mechanic can do or is it more in depth than that. i have a buddy whos dad works on the big rigs maybe he could check into doing that for me.
Old Feb 1, 2008 | 10:11 PM
  #36
F250tuff's Avatar
F250tuff
I don't believe the 7.3's had the variable vane turbo, so lot rot wouldn't be a problem in that respect. But, it can cause problems in other areas, such as oil seals, fuel seals, bearings, etc.
Old Feb 2, 2008 | 07:37 PM
  #37
msgtg's Avatar
msgtg
Wish I could help but like you I'm new to diesels and I've not experience the turbo issue....I've only read about it on the forums.
Joe
Old Feb 2, 2008 | 08:56 PM
  #38
3000 FPS's Avatar
3000 FPS
The 7.3 does not have a variable vain turbo so it does not have lot rot. That term was only for the turbo on the 6.0l because the housing is made of steel and can start to rust on the inside from sitting and then the vains which ride against that rust start to stick. On the 7.3 you do not have to worry about that. The truck your looking at with the 7.3 looks good and I would not be afraid if it. I have a 05 6.0L and love it and I also have a spare turbo sitting in my garage because I am one of those drivers that does not tow all the time and so it is very likely the turbo will stick on me.
Old Feb 3, 2008 | 06:22 PM
  #39
slowcoupe's Avatar
slowcoupe
yeh see i just like the talk about the 7.3 being the reliable work horse engine.
I do like the pick up of the 6.0 over the 7.3. i am just kind of exploring my options and found another one had the oasis run and this is what came back. hasnt had any repair since jan of 07 and it says the turbo was replaced due to clog of carbon. what do you guys think??? looks like alot of em were for recalls and small problems for stuff like interior overhead console not latching.
AWS Claim Key: 3018821 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:20-OCT-2003 Doc #:01681252
Cust Comments: RECALL 03B06 COLD OPERATION CALIBRATION PRODUCT ENHANCEMENT
Tech Comments: PCM CALIBRATION PROGRAMMED PCM TO LATEST CALIBRATION (3U7A 12A650 FUA)
AWS Claim Key: 3712388 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2003 Doc #:02143651
Cust Comments: FREE OIL CHANGE (57B98PROGRAM)
Tech Comments: 57B98 RECALL 57B98
AWS Claim Key: 4732878 Trx Code: 2 Labor Hrs: 6.1
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:26-FEB-2004 Doc #:02776151
Cust Comments: OIL LEAKING FROM REAR OF ENGINE
Tech Comments: HAS LIFT KIT, DRIVESHAFT HAS BEEN LOWERED WITH BLOCKS. MOUNTING BOLTS COULD BE LONGER
AWS Claim Key: 4712757 Trx Code: S07 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:26-FEB-2004 Doc #:02776152
Cust Comments: CUST STATES THAT VEHICLE LOST OF POWER, AND TURBO LAG,
Tech Comments: PCM CALIBRATION ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
AWS Claim Key: 4712758 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:26-FEB-2004 Doc #:02776154
Cust Comments: RECALL 03B05 INJECTION CONTROL PRESSURE, (ICP) SENSOR REPLACEMENT
Tech Comments: 03B05 REPLACE ICP
AWS Claim Key: 7798956 Trx Code: S07 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:21-SEP-2004 Doc #:04675651
Cust Comments: CUST STATES THAT FUEL GUAGE DOES NOT READ COORECTLY AFTER FILLING TANK NEEDLE STILL READS EMPTY, VERIFIED ON DRIVE BY ADVISOR
Tech Comments: INOP FUEL SENDING UNIT GAUGE ASSEMBLY FUEL TANK UNIT TEST
AWS Claim Key: 7798957 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:21-SEP-2004 Doc #:04675652
Cust Comments: LUMBAR ON DRIVERS SEAT INOP
Tech Comments: BROKEN REMOVE LEFT SEAT BACK COVER REMOVE AND REPLACE MANUAL SEAT LUMBAR
AWS Claim Key: 7819866 Trx Code: S07 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:21-SEP-2004 Doc #:04675653
Cust Comments: CUST STATES THAT AMBER CHECK ENGINE LIGHT CAME ON
Tech Comments: PCM NOT COMMANDING EGR FLOW ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
AWS Claim Key: 7798958 Trx Code: E84 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2004 Doc #:04728151
Cust Comments: CUST STATES THAT ENGINE LACKS POWER AND UNABLE TO HEAR TURBO BOOST UP
Tech Comments: STUCK OPEN EGR VALVE ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
AWS Claim Key: 8695476 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2004 Doc #:05291351
Cust Comments: CUST STATES THAT A FLUTTERING NOISE AND HISSING NOISE IS HEARD AT RIGHT CORNER OF BUMPER WHEN ACCELERATING, SOUNDS LIKE AIR COOLER BROKEN
Tech Comments: REPL LEAKING INTERCOOLER ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
AWS Claim Key: 8695477 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2004 Doc #:05291352
Cust Comments: RIGHT CORNER OF REAR BUMPER LOWER THAN OTHER SIDE
Tech Comments: FITS POORLY INSPECT FOR DAMAGE NONE FOUNG ALIGN REAR BUMPER COMPLETE AS NEC
AWS Claim Key: 13330759 Trx Code: S07 Labor Hrs: 6.3
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER FORD Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:057850A
Cust Comments: REPAIR ENGINE RUNS ROUGH WHEN FIRST STARTED COLD
Tech Comments: 33991 INJECTORS VERIFY CONCERN,PERFORMANCE DIAG,CYLS 1 3 4 8 DROP OUT COLD,PERFORMED RELATIVE COMPRESSION TEST PASS. R R VALVE COVERS AND REPLACED 1 3 4 8 INJECTORS,REROAD TEST AND CHECKED IN AM OK.
AWS Claim Key: 13330760 Trx Code: S07 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER FORD Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:057850B
Cust Comments: REPAIR ENGINE LACKS POWER WORSE WHEN COLD LIKE TURBO IS NOT WORKING
Tech Comments: 33991 TURBO EGR VALVE VERIFY CONCERN,PERFORMANCE DIAG,RETRIEVED CODES P0401,P0404,P0468,P0299. VGT PERFORMANCE TEST CYCLED VGT OPEN AND CLOSED SEVERAL TIMES,TURBO VANES STICKING,REPLACED TURBO,REMOVED EGR VALVE AND INSPECT,PLUGGED WITH CARBON,REPLACED EGR VALVE,REROAD TEST AND RETEST PASS.
AWS Claim Key: 13330761 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER FORD Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:057850C
Cust Comments: REPAIR OIL LEAK FROM ENGINE AREA
Tech Comments: 33991 ADDED DYE ROAD TEST AND INSPECT,REPLACED LEAKING HOT SIDE CAC TUBE.
AWS Claim Key: 13330762 Trx Code: E84 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER FORD Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:057850D
Cust Comments: REPAIR FOR EXCESSIVE FRONT TIRE WEAR
Tech Comments: 33999 INSPECT FRONT END,FOUND LOWER BALL JOINTS LOOSE REPLACED BOTH LOWER BALLJOINTS AND REPLACED OUTER AXLE SEALS,CHECK AND ALIGN FRONTEND
AWS Claim Key: 13330763 Trx Code: S07 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER FORD Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:057850E
Cust Comments: REPAIR TRANS HAS A DELAYED ENGAGEMENT
Tech Comments: 33990 VERIFY CONCERN,NO CODES,PRESSURE TEST PRESSURE FLUCTUATES UP AND DOWN IN FWD AND REV 30 400. R R PAN AND MAIN CONTROL, OVERHUALED MAIN CONTROL AND REPLACED PC A SOLENOID.REPLACED INLINE FILTER.REROAD TEST AND RETEST PASS.
AWS Claim Key: 13330764 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER FORD Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:057850F
Cust Comments: RECALL 59B01 ROADTEST
Tech Comments: 33999 ROAD TEST TO VERIFY REPAIRS
AWS Claim Key: 13330765 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER FORD Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:057850G
Cust Comments: RECALL 06E17 RECALIBRATION
Tech Comments: 33991 REPROGRAMMED MODULES
AWS Claim Key: 13575953 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER FORD Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:03-APR-2006 Doc #:059383A
Cust Comments: GUEST STATES THAT OVER HEAD STORAGE CONSOLE WILL NOT STAY LATCHED
Tech Comments: 34686 REPLACED OVERHEAD CONSOLE COVER
AWS Claim Key: 14759105 Trx Code: E72 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER FORD Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2007 Doc #:073260A
Cust Comments: ENGINE RUNS ROUGH WHEN FIRST STARTED COLD
Tech Comments: 43738 INJECTORS VERIFY CONCERN, HAS LATEST REFLASH AND 10W30 OIL. PERFORMANCE DIAG,POWER BALANCE CYLS 2 5 6 7 DROP OUT COLD. R R VALVE COVERS AND REPLACED 2 5 6 7 INJECTORS,REROAD TEST AND RERTEST PASS
Old Feb 3, 2008 | 07:08 PM
  #40
Citypol86's Avatar
Citypol86
I'm not knowledgeable with these and this is more to increase my own knowledge but... It seems that there were quite a few problems in '04 then '06 and again in early '07. Is this correct or are these just typical things?
Later...
Brewster...
Old Feb 3, 2008 | 07:19 PM
  #41
msgtg's Avatar
msgtg
Pal, it's kind of hard to say. I don't like the continued problem with cold starts that has resulted in all of the injectors being replaced.
How many miles are on the truck now? Remember, the motor has the 100K warranty.
Here's my question, did the owner cut back on driving the truck because of the problems or did they continue as before. If they continued to drive the truck as before it may be an ok unit.
Joe
Old Feb 3, 2008 | 08:04 PM
  #42
slowcoupe's Avatar
slowcoupe
that 03 that i just listed has 55000 miles on it even. but depending when it was manuf. it may no longer be warrantied
Old Feb 3, 2008 | 09:19 PM
  #43
msgtg's Avatar
msgtg
Drive it and see what you think. I've got one of the early 03s and I can't be more pleased with my 6.0!
Joe
Old Feb 3, 2008 | 11:01 PM
  #44
tr0y's Avatar
tr0y
Hi Slow- So it looks like you are in Vegas or near by looking at all the Craigslist trucks you are asking about. You will quickly find out that Vegas-Phoenix people are willing to pay way to much for a PSD truck.
I just recently ( sept 07 ) picked an 03 f250, only dealer issues it had was some little recall for 22K with 26K miles on it. People think the mods are worth something in reality, a modded truck has been driven hard and actually drives the resale down.
Don't pay extra for mods. Most PSDs here in Vegas are hammered. Take your time and look for a good one.
Don't pay over Private Party KBB and you should pay closer to Trade In Kbb
Tr0Y
Old Feb 4, 2008 | 12:22 PM
  #45
slowcoupe's Avatar
slowcoupe
yeh i have looked at a few craigslist trucks but others were either at ford or at a dealership thats in provo utah. i am looking for one that hs never been chipped or modded. they are hard to come by but i will keep on looking. thank you for your help.
