Sponsored by: Real Truck
new need some help.
Old Jan 27, 2008 | 04:13 PM
03KingRanch250's Avatar
03KingRanch250
You can go to the OASIS forum and someone will run it for you. They might not get back to you with it until tomorrow because it is Sunday. You should check out NADA also. KBB and NADA are close to the same but alot of banks and finance companies use NADA.
Old Jan 28, 2008 | 03:51 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
If you like it, GET IT! I knew when I saw the truck I have now that she was the one for me, and my wife is OK with that Good luck! Make sure you get the Oasis though, very important! You don't want to buy someone elses headache, no matter how purty she is!
Old Jan 28, 2008 | 10:58 AM
slowcoupe's Avatar
slowcoupe
the truck was very nice. very clean. the under carriage was clean. it sounded nice, the off road tires were a little noisy. i will just put new ones on when they wear out. im gonna talk the guy down cause i dont wanna pay for all the mods like the ps2 navi and dvd ****. thats not stuff i need. but i am gonna check on the financing.
Old Jan 28, 2008 | 07:42 PM
slowcoupe's Avatar
slowcoupe
well looks like im going to phoenix this friday to look at a few trucks. got about 7 i like im going to look at ranging from 02 to 07. hopefully i will find one i like. i like the red on but i found a few for cheaper with less miles.
Old Jan 29, 2008 | 03:37 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
If I would've bought the first one I looked at I'd be on the Cummins forums instead. Take your time and you'll know which one is "Ms. Right"! Good luck
Old Jan 29, 2008 | 12:14 PM
madjak's Avatar
madjak
I paid $27,500 last march for the truck in my signature with 50,000 miles.....pics are in my gallery.
Only thing wrong so far has been the CPS last April but it was under warranty.
Did the recall recently and will get my $100.00 back for the warranty work. This has been the best truck I've ever had!
Old Jan 30, 2008 | 04:32 PM
slowcoupe's Avatar
slowcoupe
so this means this ones a dud? the turbo was replaced last year. i hasnt been back on since sept thoguh. any input
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 1 2G05 031405 * RECAL * D50 79 115
AWS Claim Key: 126942 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05579 - * Name: FULLER FORD Ph: 619-6562500 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2003 Doc #:239521E
Cust Comments: RECALL #03T02 CALIBRATION UPDATE
Tech Comments: REPGORAMMED MODULES TO LATEST CALIBRATION
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 22 2H01 030008 3C3Z 6K854 DA N11 42 16014
AWS Claim Key: 6223507 Trx Code: E84 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:27-JUL-2005 Doc #:248076A
Cust Comments: VACUUM NOISE HEARD FROM ENGINE AT IDLE...SOP HERE
Tech Comments: PEFORMED DIAG FOUND TURBO INLET PIPED LEAKING..REMOVED TURBO..REPLACED INLET PIPES..REINSTALLED TURBO..RETEST OK
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 24 7T03 060901 F85Z 2L373 AC E29 42 18716
AWS Claim Key: 6887652 Trx Code: E83 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:252239B
Cust Comments: WHEN PRESSING TOW HAUL BUTTON CHECK ENGINE LIGHT CAME ON
Tech Comments: EEC TEST P0500..RECORD AND MONITOR PIDS..PERFORME D PINPOINT TEST AND ABS DIAG..REPLACED REAR SPEED SENSOR..RETEST ROAD TEST OK
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 24 2H02 030008 5C3Z 6F089 A D42 42 19257
AWS Claim Key: 7253032 Trx Code: S07 Labor Hrs: 6.1
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:28-SEP-2005 Doc #:253661D
Cust Comments: VEH LACKS PW ON EXCELL
Tech Comments: VERIFY CUST CONCERN AND PERFORM DIESEL ENGINE DIAG..KOEO PASS PER PCED PPT..ROADTEST MONITOR PIDS..BOOST LOW AT 18 PSI..PERFORM VGT SELF TEST..FOUND STICKING VGT SOLENOID..REPLACED VGT..REFLASHED PCM PER TSB 3 20 12..ROADTEST TO VERIFY REPAIR
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 30 * * * * * * * 25013
AWS Claim Key: 8927273 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:23-MAR-2006 Doc #:268932B
Cust Comments: EMISSION RECALL 06E17 CERTAIN 2003 AND 2004 SUPER DUTY AND EXCURSION VEHICLES FOR CONTROL MODULE RECALIBRATION
Tech Comments: REPROGRAMED PCM AS PER RECALL 06E17
AWS Claim Key: 8927274 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:23-MAR-2006 Doc #:268932C
Cust Comments: 59B01..ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE..SEE EMMISIONS RECALL 05E15 OR 06E17 FOR DETAILS
Tech Comments: ROAD TEST VEHICLE AFTER REPAIRS FOR CUSTOMER SATISFACTION AS PER RECALL 59B01.
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 30 6L17 011202 2C3Z 25519A70 AAC N30 01 25460
AWS Claim Key: 9013333 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:03-APR-2006 Doc #:269792E
Cust Comments: CEILING CONSOLE LID IS BROKEN
Tech Comments: R AND R BROKEN OVERHEAD CONSOLE, OKAY.
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 33 2H02 030008 5C3Z 6F089 A D42 42 27690
AWS Claim Key: 9718856 Trx Code: S07 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2006 Doc #:276571E
Cust Comments: TURBO DOESNT KICK IN LACKS PW
Tech Comments: VERIFY CUSTOMER CONCERN, PERFORM DIESEL PERFORMANCE CHART 1 THROUGH 15, VGT SELF TEST FOUND LOW BOOST DUE TO STUCK VGT ACTUATOR AND REFLASHED PCM AS PER TSB 03 20 12. ROAD TEST TO VERIFY REPAIR.
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 34 2E06 030008 3C3Z 9F838 EA D42 42 28374
AWS Claim Key: 9771357 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2006 Doc #:278157A
Cust Comments: VEH LACKS PW AND CHUGGS PULLING TRAILOR UP INCLINE..SEE HISTORY
Tech Comments: PERFORM DIESEL ENGINE PERFORMANCE 1 THROUGH 15, BGT SELF TEST, MONITOR PIDS UNDER LOAD. FOUND ERRATIC ICP SENSOR VOLTAGE. REPLACE ICP SENSOR. VERIFIEDREPAIR.
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 34 1B01 030201 3C3Z 6619 EA L65 D8 28374
AWS Claim Key: 9771358 Trx Code: E84 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2006 Doc #:278157B
Cust Comments: CHECK FOR OIL LEAK
Tech Comments: PERFORM OIL LEAK DIAG, INSPECT ENGINE FOUND HIGH PRESSURE OIL PUMP COVER GASKET LEAKING. REMOVED COVER AND RESEALED COVER. VERIFIED REPAIR.
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 34 1D05 031004 3C3Z 6D083 AA L65 D8 28618
AWS Claim Key: 9824745 Trx Code: E84 Labor Hrs: 5.3
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:11-JUL-2006 Doc #:278727A
Cust Comments: CUSTOMER STATES OIL LEAKING
Tech Comments: PERFORM OIL LEAK DIAG, FOUND LEAK AT REAR MAIN SEAL AND REAR ENGINE COVER GASKET. REMOVE TRANS AND RESEAL REAR ENGINE COVER GASKET AND REPLACE REAR MAIN SEAL.
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 35 2H01 030008 3C3Z 6K682 BARM E29 42 30219
AWS Claim Key: 10181473 Trx Code: S07 Labor Hrs: 14
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:21-AUG-2006 Doc #:282372A
Cust Comments: CHECK ENGINE LIGHT IS ON
Tech Comments: VERIFY CUSTOMER CONCERN. ROADTEST AND PERFORM DIESEL ENGINE PERFORMANCE CHART AND INJECTOR INTERRUPTTEST. 1326 AND 0401. CALL HOTLINE, MONITOR PIDS, VGT SELF TEST. IAT AND TURBO. REPLACED TURBO DUE TO PINPOINT TEST RA. REPLACED BIASED IAT SENSOR. REMOVED INTAKE MANIFOLD TO REMOVE AND CLEAN EXCESSIVE CARBON. RETEST AND ROADTEST TO VERIFY REPAIR.
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 46 2E03 030402 3C3Z 9E527 EBRM D36 42 43444
AWS Claim Key: 11838849 Trx Code: S07 Labor Hrs: 7.4
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:02-JUL-2007 Doc #:355722A
Cust Comments: C S THE CHECK ENGINE LIGHT IS ON
Tech Comments: 43447 #4 INJECTOR 0 PERFORMED PERFORMANCE SHEET AND GOT CODE P0272. PERFORMED COMPRESSION TEST AND FOUND ABOUT 390 PSI. PERFORMED PINPOINT TEST FOR P0272 AND FOUND THE #4 INJECTOR CAUSING THE #4 CYL TO MISFIRE. REMOEVD THE LEFT VALVE COVER AND REPLACED THE #4 INJECTOR. TEST DROVE AND RUNS GOOD
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 46 1H03 030008 4C3Z 9F452 A D02 42 44475
AWS Claim Key: 11837879 Trx Code: S07 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 01440 - * Name: FORD COUNTRY Ph: 702-5663673 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:09-JUL-2007 Doc #:09235951
Cust Comments: CUST SAYS UNIT NOT STARTING NO CRANK BUT HAS LIGHTS EST 100.00
Tech Comments: VERIFY 60, VISUAL OK, OIL OK, INT EXH REST OK, FUEL OK, FUEL PRESS OK, KOEO PCM NOT ACCESSIBLE, FOUND FUSE F2.22 20 BLOWN REPLACED FUSE BLEW INSTANTLY, UNPLUGGED ALL ITEMS ON THAT CKT FOUND FUSE NOT TO BLOW, PLUGGED EGR VALVE BACK IN WITH KEY ON, BLEW FUSE, INSPECT HARNESS OK, FOUND EGR VALVE SHORTED INTERNALLY, REPLACED VALVE AND RETEST OK
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 46 2E03 03XXXX 3C3Z 9C968 AA D02 42 44577
AWS Claim Key: 11837974 Trx Code: S07 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 01599 - * Name: COLORADO RIVER FORD LINCOLN MERCURY OF KINGMAN Ph: 928-7573131 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:13-JUL-2007 Doc #:33392801
Cust Comments: CUSTOMER STATES VEHICLE DIED AND WILL NOT START,NO CRANK ALL LIGHTS COME ON BUT WHEN TURN KEY NOTHING.
Tech Comments: IPR NO START DIAG #1 7.FUEL OK,PRESSURE:0 PSI.SELF TEST:NO COMUNICATIONWITH PCM.FUSE F2.22 BLOWN.CIRCUIT TRACD TO ALL COMPONENTS CIRCUIT SHORTED TO GROUND.PCM DISSCONNECTED, NO CHAFING.EGR VELAVE DISSCONECTED,NO CHAFFING.FAN CLUTCH DISSCONNECTED NO CHAFFING.PCM DISSCONNECTED NO CHAFFING. MAF DICONNECTED NO CHAFFING.IPR DISSCONNECTED SHORT GONE,
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 46 7S06 180101 * 12B637 * D02 28 44752
AWS Claim Key: 11873948 Trx Code: S07 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:17-JUL-2007 Doc #:309711A
Cust Comments: VEH DIED WHILE DRIVING NOW NO CRANK NO START
Tech Comments: HARD START NO START DIAG NO COMMUNICATION WITH PCMFOUND FUSE BLOWN TRACE AND LOCATE SHORT IN CKT HA RNESS R AND R ENGINE HARNESS TO GAIN ACCESS TO REPAIR WIRING RETEST AND ROAD TEST
1FTNW21P24EA34543 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-AUG-2003 17-OCT-2003 171076 USA 48 2H01 0300XX * 6K682 * E29 42 46172
AWS Claim Key: 12086111 Trx Code: S07 Labor Hrs: 8.4
Dlr Cd-Sub Cd: 20328 - * Name: SUNSET FORD, INC. Ph: 623-9778888 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2007 Doc #:314994A
Cust Comments: SERVICE ENGINE SOON LITE IS ON..RUNS OK
Tech Comments: EEC TEST P0401 RECORD AND MONITOR PIDS PERFORM PINPOINT TEST CLEAN EGR VALVE RETEST PER TSB 061906 EXCESSIVE BACK PRESSURE CLEAN TURBO PER TSB 071601 RETEST AND ROAD TEST.
Old Jan 30, 2008 | 04:41 PM
msgtg's Avatar
msgtg
Pal, this is one guys opinion...mine. I'd keep looking if it were me. The right truck is out there waiting for you...you just need to be patient. I was lucky, there wasn't anything wrong with my 150...I just wanted the 4x4 and the F250. It took me almost a year of cruising around the lots...looking and going back when I saw a truck that met my needs on the lot.
I've been rewarded with the 250 in my sig block...and I'm still grinning!
Good Luck Pal...keep running those OASIS reports...you now see how valuable they are.
Joe
Old Jan 30, 2008 | 05:00 PM
slowcoupe's Avatar
slowcoupe
yes i do. so that one is a dud then? not even worth goping out to look at?
Old Jan 30, 2008 | 06:31 PM
3000 FPS's Avatar
3000 FPS
Yes I agree with msgtg and would look around some more. Looks like you would have a headache from someone else.
Old Jan 30, 2008 | 07:13 PM
msgtg's Avatar
msgtg
If you look at the history...and the dates of the events...I truely would keep looking. The worst possible scenario would be you buying that truck and then having to keep putting it in the shop. You'd really be unhappy and you'll wind up hating the truck. There are better trucks out there waiting....
Just my 2 cents worth!
Be patient!
Joe
Old Jan 30, 2008 | 10:06 PM
swann79's Avatar
swann79
Yeah man, keep looking. That is one long OASIS report. Too many repairs for my comfort.
Old Jan 31, 2008 | 11:24 AM
  #28
slowcoupe's Avatar
slowcoupe
i asked about what was done to it. he said it died when he took it to idaho.it kept blowing a sensor so ford replaced the entire harness.
Old Feb 1, 2008 | 11:17 AM
  #29
slowcoupe's Avatar
slowcoupe
ok so another quick question about these trucks. so if i find an 03 with the 7.3 liter does that mean it comes with the better transmission(the one that would come with the 03+ 6.0 sd)?
Old Feb 1, 2008 | 04:43 PM
  #30
msgtg's Avatar
msgtg
Nope...the 7.3 is mated to it's own tranny. Word on the street is that the tranny for the 6.0 is nicer shifting and sturdier.
Joe
