6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Engine light on
Old Jan 25, 2008 | 12:09 PM
farnorthdan's Avatar
farnorthdan
Engine light on
My check engine light came on yesterday but the truck is running perfect. Called dealer and will be taking it in this afternoon. They said it has something to do with the block heater plug in???? Has anyone had a similar experience?
Old Jan 25, 2008 | 12:11 PM
rollerstud98's Avatar
rollerstud98
how can they know without even seeing the truck? It could be anything
Old Jan 25, 2008 | 12:42 PM
DelfinoTX's Avatar
DelfinoTX
Its injector #3 failing.. They need to run a contribution test on all injectors..
Old Jan 25, 2008 | 12:47 PM
SANDDEMON08's Avatar
SANDDEMON08
Is the truck stock. If not what have you done.
If it is stock whats the build date?
Old Jan 25, 2008 | 02:26 PM
tommpa's Avatar
tommpa
Mine came on friday last week. Took it in on monday and they replaced the DPF, not for sure that was the problem. They said they ran some cleaner through the motor that the EGR valve was sulfured up. They had it until Wednesday evening. Mine ran fine the whole weekend also. The owners manual said that sometimes it will clear itself if you run it a certain way. I forget what page it was on. Mine did not clear so in the shop it went.
Old Jan 26, 2008 | 03:35 PM
farnorthdan
Engine light update
Took the truck in yesterday. The Dealer said it already had the latest flash and that ford new about the engine light illumination with no apparent engine problems, they are working on an update and to check back with them in a couple of weeks......OK lets hear what you'all have to say.
Old Jan 26, 2008 | 04:43 PM
fordstroker's Avatar
fordstroker
I have the same thing going on with my truck...the check engine light came on the other day and the truck is running fine!! i'm goin to take it to the dealer this week...
Old Jan 26, 2008 | 06:42 PM
kawtiper's Avatar
kawtiper
I say GOOD LUCK I hope they figure out what the problem is.
Old Jan 26, 2008 | 07:15 PM
DieselWhisperer's Avatar
DieselWhisperer
Well my check engine light came on about 3 weeks ago and the truck ran fine. I couldn't get to the dealer for nearly a week to have it checked but on the way to the dealer that morning it went out. They put it on the computer and it showed code P006B (map sensor). They cleared DTC'S, code did not come back. Retest OK at this time. (I'm typing this from my invoice). Anyway, I got another check engine light this morning and again, no noticable difference in the way the truck runs. I will call Monday and try to get it back in to have it checked. If it's the MAP sensor again, I'm going to demand that they replace it this time.
Old Jan 26, 2008 | 07:17 PM
DieselWhisperer
One more thing, my truck is a job 1 (built in April 07). I did have the new flash done in December.
Old Jan 26, 2008 | 10:24 PM
jrtraderny's Avatar
jrtraderny
Same here, had mine in twice . Truck runs fine, cleared code and cel stays off about a month. Same explanation, dealer says drive it they'll keep clearing codes. Anyone notice if theirs is doing it only when cold or up to temp. ?
Mine only seems to do it when cold. Dealer mentioned something about thermostat but wanted to wait to hear from Ford Engineering Dept. .
jr
Old Jan 27, 2008 | 12:49 AM
rollerstud98
Just because your CEL is on does not mean the truck will run poorly, could be just some sensors aren't sending proper signals, truck can still run fine though
Old Jan 27, 2008 | 11:01 AM
team donzi's Avatar
team donzi
Had same problem Thurs, map sensor.Dealer said cold weather was the problem
Old Jan 27, 2008 | 02:18 PM
tgerner's Avatar
tgerner
Check engine light has been on in my truck three times. I took it in and they said it is becausse the engine is not coming up to temp soon enough. This I already am fighting with them about. Engine not hot no heat in cab, poor mileage, etc. anyhow they changed tstat. Light still comes on. Ford is aware of problem and they are looking at it. Believe it or not they told me to ignore the light. My question is why even have a light if we are going to ignore it and pretend there isn't a problem.
Old Jan 27, 2008 | 04:03 PM
Brian0445's Avatar
Brian0445
I have had the similar problem with my 08 too. The CEL light came on for about 2 hours and went out. I said well it cleared it's self. Then it came on again, on the way to the dealer to get my first free oil change. I asked them to run a check on why the CEL came on. They had me speek directly to the tech who stated that the coolant temp and oil temp sensors were sending false info the the computer and because of their difference that was why the light came on. He stated that ford is working for a solution but none was available at the time of service. The tech told me to start the truck up and let it reach operational temp before i drive. He didnt like it when i stated the the owners manual states not to let the truck idle for extended period of time, and that the federal law for idle time is 5 min.
