429 oil pressure low
Old 01-06-2002, 06:50 PM
forddude72's Avatar
forddude72
forddude72 is offline
i recently acquired a 71 thunderbird with a 429 in it that i'm gonna take the engine and tranny out of and put it in my 72 ford truck. it starts and runs ok but the oil pressure is very low. we replaced the guage and sender and it is still very low. i was wondering if the oil pump was the cause of the oil pressure being so low. any help would be appreciated.
thanks.
kurt
Old 01-06-2002, 09:41 PM
TBirdGuy's Avatar
TBirdGuy
TBirdGuy is offline
How many miles are on the motor? My bet is that if their are alot of miles on it, the main bearing are probably wore and allowing excessive oil loss and loss of pressure.
TBirdGuy
Old 01-07-2002, 11:13 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I agree, also , get a mechanical gauge and hook it up to the sending unit hole on the top of the block behind the intake manifold and check it there. A mechanical gauge is much more accurate than most electrics. Does the engine make any unusual noises?
Old 01-09-2002, 11:11 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
Oil pressure is a function of two things in a motor, one, the condition of the pump itself and second, the clearance on all bearings. To half a** cjeck the pump, hook the mechanical gauage close to the filter. To half a** check the bearings, hook the guage at the back of the block.
Old 01-09-2002, 11:20 AM
Just Strokin
1975Fordcj
05-26-2016 05:19 AM
maytea
10-16-2015 10:28 AM
mxer0022
04-25-2015 05:21 PM
chicagodragon
05-06-2010 08:03 AM
samckernan
02-21-2005 11:05 AM
Quick Reply: 429 oil pressure low
