351w or 460?
Old Jan 26, 2008 | 10:14 PM
quesey's Avatar
quesey
should be easy swap only thing i can think of is timing cover mite not have spot for fuel pump have to swap it off yours but long block should work. mite be best to use your oil pan ,front cover ,intake just be sure to check timing chain and the eccentric for fuel pump.i've got the same 91 351 sittin in my shop i'll look tomorrow to see if it has spot on it
good luck
john
Old Jan 27, 2008 | 08:25 AM
quesey's Avatar
quesey
no place for pump on this one its a 91 efi 351 to you'll have to use your front cover and water pump style to this ones reverse rotation so really all you'll be able to use is long block if i'm thinkin right.mite as well check on new long block @your parts house (autozone oreillys pep boys ) what ever you have there
good luck john
steve33444
49
Feb 10, 2015 08:13 AM
FoundOnRoadDominatin
20
Jan 20, 2013 09:10 AM
Murph2006
42
Feb 6, 2011 09:41 AM
jodeast
13
Nov 13, 2004 07:21 AM
orangeford
Oct 27, 2001 06:47 PM
