Wheels
Old Jan 24, 2008 | 10:44 PM
RUSTY50F1's Avatar
RUSTY50F1
Wheels
I changed my mind on the wheels, I bought a set of old style aluminum slots. Front are 14x6, and the back are 15x10 . I got them on e-bay, they need to be cleaned. What is the best way, and what do you use to clean them.
Old Jan 24, 2008 | 10:49 PM
havi's Avatar
havi
I'll have the Roast Duck
Chip Foose endorsed "Powerball" by Mothers.
Old Jan 24, 2008 | 10:50 PM
3Mike6's Avatar
3Mike6
I use acid mix with water for my truck wheels...spray it from a weedsprayer (after wetting the wheel down) and it starts to turn white.
Then I rinse it off with water...keep doing this till when you spray it and it doesn't turn white again...and that';s about the best you'll get...this is assuming the wheels are NOT polished or WERE NOT polished (sorry about the caps, just have to stress the point).
If they were/are polished, then get one of those new "flapper" things and get busy with some rouge.
Old Jan 25, 2008 | 12:30 AM
Randy Jack's Avatar
Randy Jack
I used the Flitz Ball and polish. $19.95 from a TV ad. Works really well.
Old Jan 25, 2008 | 04:03 AM
55 f350's Avatar
55 f350
im with mike here . on all the road trucks i cleaned it with a muriatic acid / water mix then started polishing them up . i have had some rims that after cleaning i've had to wet sand going to finer and finer grit's then polish so it all depends ............
Old Jan 25, 2008 | 10:15 AM
mechmagcn's Avatar
mechmagcn
Rusty, if they are the old magnesium slot wheels, "Do Not" put aluminum brightner or "mag wheel" cleaner on them. It will turn them black. My uncle did this years ago to a set and had to sand the surface off before they could be polished again.
Old Jan 25, 2008 | 10:25 AM
imlowr2's Avatar
imlowr2
Don't waist your money on the Powerball or Flitz ball, I've used both and threw them away. All I ended up doing was burning up a good cordless drill. Mother's aluminum mag cleaner works well. For magnesium and other metals, I found a product called Ultra car care products, they have a website. A bottle of metal cleaner is about $7 and lasts quite a while. Otherwise, get some rags and elbow grease. If they are really bad, use some wet or dry 2000 grit or 1500 grit and sand the surface, then polish it out.
Old Jan 25, 2008 | 06:36 PM
RUSTY50F1's Avatar
RUSTY50F1
What will happen if they are polished and I use acid on them?
Old Jan 26, 2008 | 06:10 PM
axman's Avatar
axman
the mother powerball would be my chose, every spring i have to clean my wife jeep rim up after a winter of salt attacking them here in the twin city, use to take up to 2hour per and with the powerball a 1/2 hour to a ulta shine.
if you have a heavy build up, start by lightly using scotch-brite.
then use the powerball and powermetal polish on a virable high speed drill. start slow and the slowly increase the speed until the polish is black, wipe, repeat, and repeat until you start to get the shine you want. then use a paint polish and a rag this will clean the little bit of black film that left behind and it will shine even brighter . if your happy with it but a good wax on them to potect. if your not, hit the with the powerball again. i think you'll like out come.
Old Jan 26, 2008 | 06:35 PM
mechmagcn's Avatar
mechmagcn
Rusty, if you put acid on a polished wheel, you will get a brighter color, but a dull finish. If they are already polished, I wouldn't recomend using any sort of acid, it will take some time polishing to get them back to that stage.
Old Jan 26, 2008 | 07:39 PM
eman92082's Avatar
eman92082
Naval Jelly to get them clean. After that, you can polish or whatever.......
Old Jan 26, 2008 | 09:01 PM
RUSTY50F1's Avatar
RUSTY50F1
Thanks guys; I used an aluminum cleaner by hand today and got a pretty good shine. I'll get me one of the power ball to use next. They turned out good, pics are in my gallery. My right arm is going to be sore in the morning.
Old Jan 26, 2008 | 09:18 PM
cmoritz's Avatar
cmoritz
Rusty ,Just checked out your new wheels ,Phat!!..Is that gonna be your final ride height?? Looking Good Man!!! Progress!
Old Jan 26, 2008 | 09:26 PM
COM49F1's Avatar
COM49F1
Rusty how much did your frame drop with the jag front and rear setup it looks like 12 inches to the frame bottom? can't tell from your pictures for sure?
Tom
Old Jan 27, 2008 | 01:47 PM
axman's Avatar
axman
the powerball will help your right arm, and also the tip of your fingers from being jammed. and at 1300-1500 rpm's faster those rims will SHINE!
