non spent fuel/oil will be blown out most likely in a turbo engine. unless you have really low boost during idle.
A non turbo engine will be more likely to build up in cylinder, and a turbo/supercharged engine, if operating properly will be more likely to build up into the cylinder.
This is purely by common sence.
I'm sure a combination of both is possible. But fuel will most likely be expelled into the exhaust in most situations.
If fuel is left in the cylinder to long it will break down the oil on the cylinder wall. like tim said, loosing lubrication.
Idle is important on a diesel, especially if you are one who lets it idle while you go to eat. =)
Unburnt fuel no matter what is bad.
well, even at idle. is it astrometric.. (that might be wrong) the natural presure outside forcing air into the cylinder, or is it the turbo creating the presure to flow into the cylinders?
w/o boost the cylinders will suck air on their own, find and idi and put your hand over the intake while it's running, just make sure it doesn't suck your shirt off you, jk.
as far as boost pushing stuff out the cylinder through the exhaust valve, like tim said if their is any valve overlap it is virtually irrelevant. two stroke diesel engines use the boost to blow the exhaust out the valve. if anyone reading this is doing glow plugs or injectors right now they could stick a long punch or screwdriver in there, bar the engine over, watch the closing of the intake valve in relation to when the piston starts going down after exhaust stroke.
Yeah when he told me about this it kinda interested me so I thought I would throw it out there to see what you guys had to say In my years of driving big truck have never seen this myself but also have never let my rig Idle for long periods of time
I googled this topic and read lots of threads from other sites and in most of them they talk about our 7.3,s having this problem guess they are full of it
So I came up with another question. Not specifically related to the PSD, but is there a certain egt that wet stacking occurs? I know if I prolong my idle time my egts will get close to 200 in the summer. We have a pyro on one of our tractors and during prolonged idle periods it gets close to 100.
I guess its just kinda like a cold start. With my PSD I have a decent amount of smoke when egt's are at 200, but when they get to 300 the smoke is heavily reduced.
To me that sounds like unburnt fuel smoke would that not be considered wet stacking?I bet those stage 2,s put out a lot more fuel
