2. Remove lower shroud. (Makes #4 easier if you do this first).
3. Insert key into cylinder and turn to RUN position.
4. Use a pointed tool (punch or small Phillips screwdriver) to push the release pin in and pull the whole lock cylinder out. The pin is on the bottom of the housing that holds the lock cylinder.
5. Remove tilt lever if present by unscrewing it.
6. Remove upper shroud. Pull gearshift lever down to 1st if needed.
Steve
I have just had the gauges problem on my excursion, replaced the shift lever (twice) replaced the ignition feed switch fuse which had blown, everything works again now but my overdrive switch, it is lit up od off, I have tried pushing button will not go off, tested all other fuses, actually tested them not just looked at transmission shifts perfect as before just will not go into od? Wire from od button did have bear spot that's why I changed it, tried second new shifter thinking first new one was bad, any suggestions? not a Ford expert or mechanic but kinda handy, about to pull remaining hair out, worked perfectly before, any help or suggestions greatly appreciated.
From time to time
when driving...... as the tranny shifts..
I get a whoopi cushion fart like noise.
a quick 2 second fart noise
aro6nd 2nd to third gear shift
Sounds like on the drivers side
truck is well cared for by a hobby mechanic
but runs great and looks nice
thanks would like to fix before it turn worst
