2003 Ranger Clunking between 2nd & 3rd
Old Jan 24, 2008 | 01:36 PM
kel_bs's Avatar
kel_bs
Unhappy 2003 Ranger Clunking between 2nd & 3rd
I've got 2003 Ford Ranger automatic 2.3L XLT 50,800 miles and i'm getting a rev and then clunk from 2nd to 3rd gear. Took it to the trans shop who made me get a NEW valve boby and it still has the same problem. From what I'm reading sounds like it could be something else like solenoids or gears which would be much cheaper to fix. Anyway, do I commit to rebuild or new transmission or a second opinion?????
Thanks
Kellie
Old Jan 25, 2008 | 06:59 AM
kel_bs's Avatar
kel_bs
ok, I've put the diagn machine on it myself and seems to be by passing 2nd gear???? any ideas or directions to point me in???
Old Jan 25, 2008 | 07:58 PM
Rockledge's Avatar
Rockledge
The valve body is something that a lot of people would have suggested, but apparantly that's not the problem.
I would take to another tranny shop and get it tested again. Ask them to do test the solenoids and also to do fluid psi tests.
Old Jan 28, 2008 | 07:42 AM
kel_bs's Avatar
kel_bs
Thanks for your help, I have a genisys diag machine that I'm not too familiar with but will continue to play with. I'm now wondering if a recent over heating had anything to do with this? I recently changed the thermostat which didn't work, then had the radiator flushed and that solved the slight over heating problem.
Old Jan 28, 2008 | 07:48 AM
kel_bs's Avatar
kel_bs
I forgot that I had checked the trans fluid after the radiator episode and it was low so I put some fluid in it and realized later that it was merc III????? Thats when the clunking got worst. Anyway, with the neww valve body the fluid has been changed but do you think it could be a problem?
Old Jan 28, 2008 | 07:55 AM
Rockledge's Avatar
Rockledge
Your tranny is supposed to have Mercon V fluid. The wrong fluid could (and in most cases, will) make shifting harder. However, your tranny problem sounds like something other than hard shifts.
As you noted, there could be other mechanical causes, such as a bad EPC solenoid, for example.
Old Jan 28, 2008 | 09:52 AM
kel_bs's Avatar
kel_bs
I'm not getting any touble codes, I don't have the flashing OD light but it's still skipping 2nd gear??????
