OD OFF Light
Old Jan 24, 2008 | 06:55 PM
Todd525's Avatar
Todd525
REally???? Heck, even my edge evo reads some generic tranny codes. Anyhow, I might have read this wrong, but was the guy that started this a ford engineer for tranny?? Why is he going to replace a sensor without having the codes read??? Thats a little weird. Ok, A LOT weird. It could be one of 200 things. GO GET THE CODES READ.
Old Jan 24, 2008 | 07:13 PM
Action4478's Avatar
Action4478
The sensor & checking the wiring are a cheap test...If he has to go to ford it may be much more ...(you are at their mercy)
Most guys don't have a scanner & don't want to go to a place that has one ,,,thats why most of them post here,,,
If you like ,, we can always answer ,,,"get the codes read "
Then it will be easier all the way around (boring maybe) ,but easier
just a thought,,,
Old Jan 24, 2008 | 07:21 PM
kawa's Avatar
kawa
Originally Posted by Mark Kovalsky
Because Ford wrote the software in the PCM to require a Ford specific scan tool to read trans codes. Not all code readers can do it. The EPA requires that all OBDII scan tools be able to read codes the turn on the check engine light, but there is no requirements for codes that flash the OD light.
Thanks Mark, that a good piece of info to know. I'll bet there is only a very small hand full of guru's out there that knew that. (I just know I'm gonna get beat up for this)
Rog
Old Jan 24, 2008 | 07:23 PM
Action4478's Avatar
Action4478
Rog
How big are your hands ?....
Old Jan 24, 2008 | 07:28 PM
kawa's Avatar
kawa
NO! It is Icebox's thread. Mark (Engineer) told him that just replacing parts randomly was not diagnosing anything. Mark told Icebox to get the codes read then the forum could help him.
Icebox took it the wrong way and was on his way to throwing a tantrum.
That is the "Reader's Digest" version and it will proly pi$$ someone off as well.
Sometimes "HELP" is not all milk and honey.
Rog
Old Jan 24, 2008 | 07:40 PM
MADVAN's Avatar
MADVAN
LLiB
Old Jan 24, 2008 | 07:43 PM
Action4478's Avatar
Action4478
Old Jan 24, 2008 | 07:45 PM
Todd525's Avatar
Todd525
Dang, apparently I am lucky around here. Both autozone and advanced auto here in town have the ability to pull all codes. I think autozone charges 2 bucks for theirs. I also have a garage on the other side of town that pulls all codes as well. They do it free. They even have a body code reader for chevys, which is hard to come buy around here. THE LAST PLACE ON EARTH that I would get my codes read is at the ford dealership. They know as much about diesels as my daughter does. Well, atleast their master tech does.....LOL Not to mention they charge something like 65 bucks to hook up the scanner. Here in my town, only the morons go there. IS your guys towns and cities the same way, or am I the exception to the rule?
Old Jan 24, 2008 | 07:48 PM
Action4478's Avatar
Action4478
I have my own scanner ,, so my knowlege is limited .....
this is the first I have heard of an auto zone with a PSD capable scanner....
Old Jan 24, 2008 | 08:56 PM
Todd525's Avatar
Todd525
their the ones with a body code reader too. I thought that they all had em, but my brother is telling me otherwise. he said in Delaware ohio, not 20 min from me, they have NOTHING. No body codes, NOTHING.
Old Mar 24, 2008 | 07:12 AM
Tarpon1's Avatar
Tarpon1
I have Icebox's problem.
Icebox- what's the verdict-- Problem solved?
Finally- If I go to an Autozone,etc.. will they give a diagnostic after the codes are pulled??
Finally2; Must the "OFF" stalk light be in flash mode while codes are pulled?
Old Mar 24, 2008 | 08:42 AM
Action4478's Avatar
Action4478
If they actually can pull them ,,,most likely not ,,
If they can ,,tell us what the codes were...
No ....
Old Mar 24, 2008 | 04:50 PM
  #28
immastrokinnow's Avatar
immastrokinnow
i had the light start flashing at me. then 2 miles later the front seal blew out. not sure if they are related at all. but im in the process of doing my homework on a good trans now...
ST58
Feb 16, 2015 08:37 AM
TX92F150
Aug 8, 2013 08:32 PM
mdlf350
Jan 17, 2010 12:01 PM
sonsila
21
Aug 31, 2009 05:59 AM
glennn
Oct 31, 2006 05:52 PM
