Sponsored by: Real Truck
Wheel hop?
Old Jan 23, 2008 | 03:54 PM
40searay's Avatar
40searay
Wheel hop?
I just got some new toyo a/t 315/75/16's on my 2004 F350 4wd. All seems well except at 40 mph, the whole truck feels like its going over wavy pavement. When I look in the rear view mirror, it SEEMS like the back is bouncing more than the front. Is this just a balancing issue?
Old Jan 23, 2008 | 04:06 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
What for pressures are you running in the tires? Maybe lower rear pressure a bit?
Old Jan 23, 2008 | 04:10 PM
350z's Avatar
350z
Check the air pressure first , then have them recheck the balance .
Old Jan 23, 2008 | 04:29 PM
40searay's Avatar
40searay
they are all at 54 psi.
Old Jan 23, 2008 | 04:33 PM
40searay's Avatar
40searay
I'll lower them to 50 (max pressure per the Toyo website) and see if that helps.
Old Jan 23, 2008 | 06:03 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
You could prob. even go lower, I run 45 in front and 40 in back unless towing
Old Jan 23, 2008 | 08:14 PM
high ho silver's Avatar
high ho silver
Can you see any signs of a small dot of paint on the sidewall anywhere on either tire? When I got my new tires I notice a small green dot on each tire. Tire store said it was to let the tech know where to mount the tire in relation to the metal valve stem. I guess the stem is just heavy enough to throw the balance out and no tire is perfectly balanced new so the manufacturer tries to counter balance the issue.
Old Jan 29, 2008 | 08:01 AM
40searay's Avatar
40searay
I don't have metal stems. I lowered the air pressure but I still get the hop between 37 and 40 mph.
Old Jan 29, 2008 | 03:21 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
I'd take it back to the tire dealer, maybe there's a broken belt in one of the tires? Have them even take it for a ride so they can see for themselves.
