Oil Consumption
Old Jan 23, 2008 | 03:14 PM
jkh04200's Avatar
jkh04200
Oil Consumption
95 PSD.
What is normal? I'm using about 2 qts every 5K. 191K miles
Old Jan 23, 2008 | 03:27 PM
IceboxFX's Avatar
IceboxFX
I dont burn any, but that seems a bit high to me.
Old Jan 23, 2008 | 03:52 PM
tjbeggs's Avatar
tjbeggs
I would say that is pretty good. I think Ford says 1 quart every 1K is ok. I would be very happy with 2 ever 5K.
Old Jan 23, 2008 | 03:53 PM
jkh04200's Avatar
jkh04200
What gives???? I bought the truck with 125K on it from my uncle. I have every receipt he always had the oil changed at 3k. I go 5K because i drive so much. I do use rotella. Might try delo. This thing has had a very eeasy life.
Old Jan 23, 2008 | 04:04 PM
glasseater's Avatar
glasseater
2qts every 5k is perfectly fine don't worry about it unless as tj said it uses more than 1qt every 1k miles
Old Jan 23, 2008 | 04:29 PM
884x4broncoII's Avatar
884x4broncoII
a buddy of mine uses 1 quart every 100 miles. and theres not one drop of oil dripping under neath it. he is just going to drive it till it dies. but it hasent yet although he is spending as much on motor oil as fuel LOL
Old Jan 23, 2008 | 04:30 PM
glasseater's Avatar
glasseater
is it a diesel or a gasser?? my sister's bronco empties out 4 qts every 500 miles..... it's pathetic lol
Old Jan 23, 2008 | 04:35 PM
884x4broncoII
acualy its a pre-powerstroke 7.3 it was a great van too till all of a sudden it started going threw oil. it always used a kinda high amount like a quart every 700 miles our so. it only has like 120,000 miles on it as well. but it used to be owned by the railroad, who knows what they did to that poor thing. but anywha he checked the oil one day before leaving and added some got 100 miles up the road he said he pulled off the freeway and the engin sounded almost like the incetors fiering realy loud, he checked the oil and it was almost 3 quarts low. and been going threw about 1 quart every hundrid miles sense
Old Jan 23, 2008 | 04:39 PM
glasseater's Avatar
glasseater
wow maybe someone more experienced than myself can make a suggestion but... injector o-rings?? can they leak that much??
Old Jan 23, 2008 | 08:58 PM
farmert's Avatar
farmert
884X4broncoII Has he ever servced the CDR valve? It is that tuna can looking thing, held on with two bolts on the drivers side valve cover if it has a turbo. If a nonturbo it is under the air cleaner on the back side of the air intake.If it has not been cleaned in a while it can suck oil vapors out of the crankcase and burn it causing high oil consumption. It should be cleaned everyother oil change. To clean remove it and soak it in solvent or gas.Repeat until the solvent is clear, then let air dry. Do not use compressed air as that can rupture the diaphram on the inside.
tjbeggs's Avatar
tjbeggs
O-rings..Not on an IDI. they don't have injectors like ours. For 1 quart every 100 miles I would bank on a cracked/hole in a piston! or 8!
farmert good call. I haven't worked on those at all other than injection pumps but I have heard of what your are talking about.******** type=text/javascript> vbmenu_register("postmenu_5620978", true); *********>
Old Jan 23, 2008 | 10:35 PM
884x4broncoII
probably hasent been cleaned in a long time. but i know if you pull my 96 psd up next to it the van sounds like ****. i mean desiles are rattly but in compairion to my psd its like night and day
bigswede
Kansas Chapter
Sep 18, 2013 07:11 AM
jimwilsonmasonry
16
Sep 24, 2012 08:49 AM
linkford
Nov 2, 2007 10:21 PM
bigbadwolfe
Jan 18, 2007 07:17 PM
jadel
17
Feb 13, 2005 10:38 PM
