Red Loctite
Old Jan 23, 2008 | 02:25 PM
merc546's Avatar
merc546
Red Loctite
Anybody know of a way to remove a bolt/screw that was installed with red loctite (should have used blue my mistake). This is a set screw on my steering column u joint (need to remove steering column).
I don't think heat will work just because it's near the exhaust manifold and it acts like it's welded in there. Thanks
Old Jan 23, 2008 | 04:55 PM
mtflat's Avatar
mtflat
Heat or more red loctite is what I've always heard.
Old Jan 23, 2008 | 05:05 PM
Randy Jack's Avatar
Randy Jack
Depending on how accessible the area is, heat, like from a pencil or bottle torch, is the answer. That will crystalize the loctite. Then, while still hot, a few smacks with a hammer will break the bond and release the set screw. The bigger problem with a set screw is that there isn't very much purchase to turn it. Keep at it. Have patience. It will break loose.
The bad news will be if the heat dries out the uni joint. Lube it well before reinstalling everything.
Old Jan 23, 2008 | 05:20 PM
Mick1930's Avatar
Mick1930
That is what I heard as well..apply heat and remove hot.
The locitie is an anaerobic adhesive and cures in the absence of air.
Old Jan 23, 2008 | 06:46 PM
merc546's Avatar
merc546
Ok thanks. I guess I'll try more heat in the morning after I go to sears and replace the allen wrench that I broke trying to get the set screw loose.
All of this because I'm changing over to a CPP firewall mounted booster and master cyl (all ready have a firewall mounted booster and M/C but my brakes are like a on off switch so thought I would try this (found another way to waste more money)) and where they want you to install it happens to land right in the middle of my wiring. I'm not moving the wiring so I guess a new mounting bracket is in the future.
Again thanks for the info. Chuck
Old Jan 23, 2008 | 09:50 PM
mtflat's Avatar
mtflat
Before you go crazy with the hot wrench, I really did hear on another forum that an application of red loctite works as a solvent - just hearsay, but if it works...............and it can't make the problem worse. fwiw
Old Jan 23, 2008 | 11:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Loctite sells a solvent, too. It smells like acetone (hint). I've never had that much trouble getting bolts/nuts set with red (#271) off, I must not be using it right.
Old Jan 24, 2008 | 09:09 AM
AXracer's Avatar
AXracer
red locktite requires a fair amount of heat to remove, I don't remember the exact temp but it's higher than you'd want to hold or that your exhaust heats it to. Use a propane torch to heat.
Old Jan 24, 2008 | 12:35 PM
ghall's Avatar
ghall
Go direct to the source...
http://www.loctite.com/int_henkel/lo...d=111&layout=2
enter 271 as search criteria...
click 'english' and a PDF document will load... heat is listed at 250°C
Old Jan 24, 2008 | 01:23 PM
CharlieLed's Avatar
CharlieLed
250 degrees doesn't seen like a lot of heat...
Old Jan 24, 2008 | 01:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
250 C. is 480 deg. F.
I've used it for years on flywheel bolts and such, clean threads, etc. An impact wrench takes them right out without heat. They don't ever come loose so I assume it's working. I could see where it would really lock up a small setscrew.
Old Jan 24, 2008 | 01:31 PM
CharlieLed's Avatar
CharlieLed
I hate it when they do that! What was wrong with just Fahrenheit anyway?
Old Jan 24, 2008 | 03:37 PM
Fomoko1's Avatar
Fomoko1
I hate C too and WE have to live with it all the time!
Old Jan 24, 2008 | 05:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Teachers are still telling kids that the complete switchover (in the US) to metric is "around the corner". That's what they were telling me in HS 30+ yrs ago. Must be a gov't run program to switch...
Old Jan 25, 2008 | 12:13 PM
merc546's Avatar
merc546
Heat worked. About 5 seconds of heat from a propane torch and they turned out like nothing was ever stopping them (snapped a 5/32 allen head wrench/socket on the first one) anyway thanks again.
I think I will use blue next time.
Chuck
