can anyone tell where i can get a 429/460
timing cover? also need a crank for a 429, does
any body know anyone who sells a crank kit for
a 429.one more thing, has anyone installed the
moroso oil pump spring in there oil pump?they say
it fit 351c but some body told me that it will work
in a 429/460. any input would be greatly appricated.
You should be able to get a timing cover from a wrecking yard. PAW has crank kits for a 429. I've also heard that the Moroso spring will work in a 429-460 pump.
