Iowa Chapter Join Chapter, Leader:
engine heater
Old Jan 23, 2008 | 10:15 AM
jkbeegs's Avatar
jkbeegs
engine heater
Living in Iowa can you leave your engine heater on for a long period of time on a 2006 6.0 liter diesel engine?
Old Jan 23, 2008 | 12:04 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
I've had mine on since Sunday! I don't think it's a big deal when it's this cold.
Old Jan 24, 2008 | 06:43 AM
fellro86's Avatar
fellro86
Do it all the time with trucks, tractors, the only thing it affects is the power bill, and really, it doesn't hit that too bad, something like 15 cents a day to be plugged in.
Old Jan 24, 2008 | 05:00 PM
428HIGHBOY's Avatar
428HIGHBOY
Only 15 cents? How many watts?
Old Jan 24, 2008 | 05:39 PM
fellro86's Avatar
fellro86
That was a friend telling me what it cost to keep their semi plugged in.
Old Jan 24, 2008 | 09:03 PM
fellro86's Avatar
fellro86
I just remembered a little test I did a while back, had my dad's 84 plugged in, and watched the meter. By the numbers given on that, it was on track to cost about $30 a month if it were plugged in 24/7.I read the meter at the same time 24 hours apart, and our power is about 10 cents a kilowatt/hour if I remember correctly.
Old Jan 24, 2008 | 09:14 PM
428HIGHBOY's Avatar
428HIGHBOY
24 hours x 30 days =720 hours
500 watts / 1000 (kilo) = .5 kilowatt
720 hrs x .5 kw = 360 kilowatt hours
10 cents x 360 kwh = $36
Old Jan 26, 2008 | 08:50 AM
beaners1's Avatar
beaners1
They make little meters to check electrical usage, just plug it in then plug in whatever, tells you how much it uses. Bought mine for $45 and I found out I needed a new deep freeze pretty badly. Kinda nice to know what uses what.
Old Jan 26, 2008 | 06:11 PM
428HIGHBOY's Avatar
428HIGHBOY
Ohms law works too. E=I X R
Old Jan 27, 2008 | 06:50 AM
fellro86's Avatar
fellro86
Ohms is nice for estimates, but without knowing the actual resistance and current, it is an educated guess. Ratings don't guarantee usage. I do know what themeter said for usage, so that's why I went that way. (Not to mention, forgot to try figuring it by Ohm's law...)
buckmasters
6.7L Power Stroke Diesel
Oct 30, 2011 09:05 AM
iowa 7.3
Apr 26, 2011 11:13 AM
danonbar
Jan 22, 2005 10:11 PM
F150y2k
Aug 6, 2003 10:24 PM
