Sponsored by: Real Truck
good replacement battery?
Old Jan 23, 2008 | 12:28 AM
mpbpulaski's Avatar
mpbpulaski
I need to get new batteries for my '02 f350. Can anybody suggest a good, dependable brand? Or one to definitely avoid?
Thanks
Old Jan 23, 2008 | 12:38 AM
DCSpecial's Avatar
DCSpecial
I've been the happiest with the Interstate MTPs I just put in the 06 in the fall.
Old Jan 23, 2008 | 12:43 AM
GregsSD's Avatar
GregsSD
I've been hearing alot of good things about Deka batteries, That will be my next set.
Old Jan 23, 2008 | 12:47 AM
dcf4x4's Avatar
dcf4x4
if you dig deep enough it seems that most batteries are made by the same company (I'm not kidding, either), just labeled differently. Manufacture isn't a huge thing. The good news is that you will have to find the biggest, and strongest battery out there for bragging rights because that is what our truck needs anyway.
I've bought from walmart, sam's club, Pep boys, auto zone, sears, then back to walmart. (different vehicles but always the biggest battery)
They all last about 2 years and I'm really hard on batteries. (extended radio listening, lots of accessories)
Old Jan 23, 2008 | 01:02 AM
powerstrokin007's Avatar
powerstrokin007
Just put 2 Energizers in mine after it was sitting for 6 months while I was deployed. Was hoping to go a bit longer on the Motorcraft batteries.
Old Jan 23, 2008 | 09:09 AM
mpbpulaski's Avatar
mpbpulaski
I've always had good luck with the Motorcraft batteries. The ones in my '97 were still good when I sold it after 8 years and 166,000 miles. My '02 has 162k and the batteries just started giving me problems, I think mostly from things getting left on a few times lately and them being run down to nothing.
I just want something good, not something that will be junk in a year.
Old Jan 23, 2008 | 09:50 AM
vettdvr's Avatar
vettdvr
The Duralast in our F150 was cranking slow in 2003 when my son said to replace it because it was 4 years old. It is still cranking slow but still working. Today it is 9 years old and still going.
Old Jan 23, 2008 | 10:36 AM
Jim59's Avatar
Jim59
Just a little more info from CR ......
http://www.consumerreports.org/cro/c...eries-rate.htm
You'll notice that the manufacurer's claimed CCA are not always confirmed by CR's testing. Do you live up north, or down south?
I've also had good luck with OEM batteries ..... both Mortorcraft and Honda's.
Good luck.
Old Jan 23, 2008 | 10:42 AM
03KingRanch250's Avatar
03KingRanch250
I just put in 2 Duralast Gold's. 850CCA/1000CA. They are holding up really well so far.
Old Jan 23, 2008 | 10:46 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I went back with the Motorcraft 850 cold crank. They lasted so long the first time.
Old Jan 23, 2008 | 11:22 AM
boxcar1974's Avatar
boxcar1974
Same here. The Motorcraft battery is pretty good. Mine is 5 years old and is going through its 5th New England winter and still going fine. The key to longevity is keeping the terminals clean, making sure the cells are full of distilled water, and a battery tender trickle charger if you let the vehicle sit for long periods.
Old Jan 23, 2008 | 12:01 PM
redford's Avatar
redford
FTE Leadership Emeritus
Which ever battery you purchase, I always recommend you get the stupid little felt washers that go in the battery posts. They really do work well in preventing corrosion and are very cheap insurance.
As for the batteries, get the biggest NAPA, DIE HARD or MOTORCRAFT you can get, (most CCA capacity). Replace them both; inspect and replace any cables that are corroded or frayed.
Old Jan 23, 2008 | 12:04 PM
miller_feed
I forgot about the little washers, good call. I remember them from as long as I have been driving, long time.
Old Jan 23, 2008 | 12:11 PM
rxk9394's Avatar
rxk9394
for those with Costco memberships, their Kirkland Signature batteries for our trucks have a "claimed" CCA of 900 (even though I trust a Costco claim more than most any other retail outlet).
I just picked up 2 for $70 a piece a couple of months ago and they've turned over in great shape in as low as -10 degree weather. Plus, the Costco return policy is head and shoulders above anywhere else so as far as I'm concerned, you can't go wrong there...
Rex
05 F-350 PSD
Old Jan 23, 2008 | 12:12 PM
redford's Avatar
redford
Did the Model T have a battery?
