fe crank casting
Old Jan 22, 2008 | 08:36 PM
pnfarms's Avatar
pnfarms
fe crank casting
I have a FE crank with a casting of U3. What is this crank from? The stroke is 3.92 with a bore of 4.06 bored over .30. The block has no casting number except for a number on the left rear of block, from I under stand is a vin Number from the car it was in.
Old Jan 22, 2008 | 09:52 PM
Redmanbob's Avatar
Redmanbob
re-measure the stroke, the bore should be 4.080 if it's an .030 over bored 390 and the stroke 3.784"
Old Jan 23, 2008 | 12:05 AM
fordeverpower's Avatar
fordeverpower
you have to measure the deck clearance and subtract it from your measurement when the piston is at bdc.
Old Jan 23, 2008 | 04:09 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
3U crank is a 390 crank 3.78 stroke.
Flat 'n Fat
Jul 24, 2022 04:50 PM
Nevada Mike
Jun 13, 2014 04:08 PM
rh428wf
Jul 9, 2011 06:04 PM
393STROKER
May 12, 2009 03:34 PM
jacob_9249
Jul 26, 2008 08:04 AM
