From what I can see, there are a couple different thermocouples for pyrometers. There is a Type K Thermocouple and another kind. What is the difference? Does it matter which I use for a pyrometer measuring exhaust temperatures in the manifold?
I don't know what the other one is but a K type can measure between -200 and 1250 C. This will more that cover the temperature range you should see for EGT's.
Type K is a standard T/C for high temperature applications. The various T/C materails produce differrent voltages responses over different temperatrue ranges. Just make sure your reader is compatible with the type of T/C you use.
I've installed many thermocouples in asphalts plants over the years. The other type is a "type J". I have never heard of it for automotive applications.
The difference between the two is the millivolts that is produced. The gauge is either compatible for type J or type K. not interchangable!
