Door Hinges
Old Jan 22, 2008 | 12:25 PM
rirwin's Avatar
rirwin
Door Hinges
I noticed the drivers side door "drops" a little bit when I open it. The top hinge has some play in it. This, of course, destroyed the striker bushing. I can get the bushing at the auto parts store, no biggie. Is there a hinge kit available for the OBS trucks, or do I have to get the whole hinge? Thanks.
Old Jan 22, 2008 | 12:28 PM
tjbeggs's Avatar
tjbeggs
Yes there is a pin and bushing kit availible for the hinges. The one I buy from Napa come with hardware for 1 hinge so to do a whole door you need two kits.
IceboxFX's Avatar
IceboxFX
you might be able to bend it back into place with a pry bar under your door and onto the floor of your truck. I think thats the way we did that on my buddy's 97 and it worked and didnt ruin anything. i dont blame you tho if you dont wanna do that, but i dont know the answer to your question sorry, just my 2 cents
Old Jan 22, 2008 | 12:43 PM
rirwin's Avatar
rirwin
So the same kit will do top or bottom hinge?
Old Jan 22, 2008 | 02:18 PM
Action4478's Avatar
Action4478
Yes ,, make sure you DO NOT REMOVE THE HINGES FROM THE BODY...(did I say that loud enough)?
You can actually do one hinge at a time ,without removing the door,,,,,
Old Jan 22, 2008 | 03:04 PM
tjbeggs's Avatar
tjbeggs
yep what Rick said! The top and bottom pins are different lenght but the kit makes provision for that.
Old Jan 22, 2008 | 09:17 PM
rirwin's Avatar
rirwin
Thanks guys. I picked up a couple of kits this evening. I'll give it a go in the A.M.
Again, much thanks.
Old Jan 22, 2008 | 09:19 PM
Neal 97 250's Avatar
Neal 97 250
Good luck. It is not hard just have a jack or stands to support the door. Looks like you are on the right track here.
Old Jan 23, 2008 | 04:14 PM
rirwin's Avatar
rirwin
Wow! That was easy. An air chessel on the old pins. Had'em out in 5 minutes. I did find that putting a slight bevel on the edge of the bushings with a sander made it a lot easier to start them in the hole. Once again, grassy-***.
jvmcc
Aug 31, 2014 11:44 AM
carver94f350
Sep 16, 2012 08:34 PM
MNTBUGGY
Feb 20, 2012 07:50 PM
Roamer
May 8, 2009 07:46 PM
Roamer
'80-'86 FAQs (Frequently Asked Questions)
