What's the Trick???
Old Jan 23, 2008 | 06:54 AM
Byrddog's Avatar
Byrddog
Guys I got it!
I loosined the exhaust before the headers and it was no problem at all,
You can even get a socket in there then.
So if anybody esle trys this thats the trick.
Thanks guys,
Harry
Old Jan 23, 2008 | 07:59 AM
iasrap's Avatar
iasrap
<highjack notice>
So I know a bit about these trucks, but I have been fortunate enough not to need to bother with the fuel delivery system. I have a perpetual fuel leak, but it is just a few drips a day, so i have not bothered with it. It collects on the bottom side of the engine along the fuel supply lines just after their bend to parallel the frame back to the tanks. I have looked all over the engine in front and cannot find the leak, I got under to look for it, and my line of sight dies before I find the leak.
Is this common? How do I fix it?
Old Jan 23, 2008 | 08:33 AM
Todd525's Avatar
Todd525
you have to know where the leak is coming from first. Look into the valley of your engine. Is it wet or dry??? If its dry, then it might be a gasket from the HPL at the back of the heads. If the valley is wet, its the fuel pump.
Old Jan 23, 2008 | 04:09 PM
IceboxFX's Avatar
IceboxFX
Originally Posted by Byrddog
Guys I got it!
Thanks guys,
Harry
You talkin about the downpipe and the line right under the turbo?
Old Jan 23, 2008 | 04:11 PM
Byrddog's Avatar
Byrddog
My high pressure lines were the problem fuel was leaking down into the valley and running down the back of the engine, from wherethe lines connect into the heads. iasrap, your fuel lines there in the back of the engine are probably your cause.
Hope this helps a little.
Byrddog
iuecbrad
1997 - 2003 F150
Sep 20, 2015 12:39 PM
56fordfella
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 20, 2015 10:12 AM
devils toy
Mar 19, 2015 11:09 PM
KAGAN21
13
Nov 29, 2014 03:50 PM
r___r
Dec 16, 2013 10:45 PM
