Transmission Fluid
Old Jan 27, 2008 | 12:06 PM
Gage2502's Avatar
Gage2502
Thanks again amm88 for the info.
~Gage~
Old Jan 27, 2008 | 01:48 PM
amm888's Avatar
amm888
~Gage~
glad i could help (i know i've gotten a ton of help from this forum)
Old Apr 17, 2008 | 09:28 PM
Gage2502's Avatar
Gage2502
I was under my 2000 Expedition 4x4 the other day and looked at the trans and now I know that I have a drain plug on the trans pan, I also know that I have that plug that covers the torque converter. Question is that can I hand turn the torque converter or do I have to start and stop the engine a few times in order to drain the fluid?
Any tips?
Thanks ~Gage~
Old Apr 17, 2008 | 11:32 PM
sbclemens's Avatar
sbclemens
Use a remote starter (or an assistant) to bump the engine over until the plug on the torque converter is visible.
Old Apr 18, 2008 | 10:50 AM
2000Expy's Avatar
2000Expy
Don't be afraid to change the oil in your transmission. All that stuff about ruining your transmission by changing oil is myth and hogwash. Just make sure you use an oil and filter that is correct for your vehicle.
I've had my transmission flushed three times and recently changed the oil out completely with synthetic. It has over 158K miles on it and runs like a champ.
Old Apr 18, 2008 | 01:13 PM
Gage2502's Avatar
Gage2502
As for the filter I went to Auto Zone and all they had was a Fram filter, should I go to my dealer and buy a motorcraft? Also I can reuse the gasket too right?
Thanks ~Gage~
Old Apr 18, 2008 | 05:55 PM
sbclemens's Avatar
sbclemens
Pick up the filter at your dealer. The pan gasket can be reused.
Old May 22, 2008 | 03:56 PM
Gage2502's Avatar
Gage2502
You need to spin the torque converter (might have to bump the motor or hand turn it) until the drain plug is accessable. Is it pobbable to hand turn the torque converter?
What if I cant drain the torque converter? Is it ok to leave the old fluid in it?
Thanks. ~Gage~
Old May 23, 2008 | 04:55 PM
sbclemens's Avatar
sbclemens
You should have no problems draining the torque converter. If you decide not to, then just change your filter and refill the pan with fresh fluid.
Old May 24, 2008 | 10:05 AM
Gage2502's Avatar
Gage2502
Is the drain plug on the torque converter a hex bolt? It looks like it 3/8" in size.
~Gage~
Old May 24, 2008 | 10:08 AM
Gage2502's Avatar
Gage2502
The bolt on there is 7/16" in size.
Does that seem right?
~Gage~
Wingdreamer
2009 - 2014 F150
35
Aug 12, 2020 01:43 PM
Gage2502
Feb 12, 2015 04:06 PM
abyars111
Apr 16, 2013 05:36 PM
Gage2502
May 30, 2008 10:07 PM
03KingRanchF250
Mar 31, 2007 01:25 PM
