Well, ole' Blue kinda let me down at work yesterday.
It was -5 degrees F, but still.
Now, before I go out and work on this (it's cold as hell) I want to be sure I'm running down the right track.
I had noticed the truck this winter didn't seem to crank quite as fast, hard to turn over as if the engine was more difficult to turn over - battery itself is near new, and I keep it on the charger overnight in the wintertime, and I keep truck garaged. Plus, read further - it ain't the battery itself anyway.
Yesterday it turned over only slightly. I keep one of those portable jump-start batteries/air-compressors with me - that didn't help. A co-worker tried a jump start with his rig - nothing. Just a nice "click".
So, if I can rule out bad/weak electrical connections (doubtful, I even run the negative battery cable directly to the starter frame) ;
is a failure mode for starters just to get weak like this?
I'm just thinkin' - maybe the starter itself is frozen w/ water/slush/salt whatnot? My plan is, since it would start in colder (but not this cold) weather take a propane torch out and heat up the starter good, and get 'er home.
This is a rebuilt starter maybe 2 or 3 years old if that helps.
check your battery terminals. I hadthe smae problem and when i tried to jump it. nothing. so i wiggled the battery terminals and poof. three turns, she fired. so i i am gonna replace my cables. dont know if this helps ya. but thats what i did when a jump wouldnt work for me.
Well I got 'er started. I checked connections and they seemed good, so I used my handy propane brazing torch for about 5 minutes on the starter itself. It turned over slow but enough to start.
Now I gotta find a new starter somewhere, quick. If I would have ordered one earlier today it would have been here tomorrow. Nobody seems to have one in stock. The part number I have is C2SZ-11002-A; anybody have a different/better cross?
Starters can definately grow old and tired. Windings can corrode..maybe a few break. Not sure for sure, but through the years I've had ones that only did the job when it was moderate temp. Some will get worse when they get too hot (like when headers are mounted too close).
Up my way, NAPA is pretty good about being able to get you a starter.
One last thought -- it being cold out and all -- what weight oil are you running?
My NEW starter motor sometimes groans and can't push over the engine after it's been running for a while and the compression is up. It'll hesitate, but after a couple go's it'll get it crankin'!
How about a lot of motor condensation - I use my truck as a daily driver, and it doesn't get warmed up - motor could be basically frozen, lol. But heating the starter did work (I'm so smart, I scare me, ha ha) Yep - NAPA was the one who said they could have one by tomorrow, but I balked at ordering one, cuz at that point I wasn't entirely certain I needed a new one. I'll have to check, but this one is only a couple years old - and it already crapped out on me, sheesh.
Had one ford that seemed to go through starters more often than it should have. Might see if there is a guy in town that rebuilds starters. We have a guy that does alternators and such. He goes through and replaces everything that needs done. He is generaly cheaper than getting a whole new unit. Not sure but one of these guys could probably hop it up a tad to help on those cold starts. These guys are getting harder to find now but check around and you might find one.
ya know, i did do a thread asking bout the high torque starters for the y-block. the high torque might be a better bet for us guys who live in the northern states that have to deal with freezing cold temps. I noticed that my starter give a lil fight even when its warm out for the first start in the morning. heres the website for that high torque starter:http://www.autoelec.com/html/ford_y_...uction_st.html
Might see if there is a guy in town that rebuilds starters. We have a guy that does alternators and such. These guys are getting harder to find now but check around and you might find one.
Hm, greatidea, and I know just the place.... Old school shop, filled to the brim with motors all over the place, and would keep $$$ local.
One thing, I cored the original starter the last time, (I think! wait a sec, time to check "the pile") was this a mistake? In other words are all starters basically the same? The innards that is? What is really done on a starter 'rebuild'?
edit: hey thanks 64Ford, for the high-torque starter link. 160 smackaroos - not bad, I might consider that depending. Anyway I look at it, I gotta crawl under and change a starter out sometime soon. At least I gotta garage. I may just bring the torch to work for a while, heh.
Those questions are beyond my expertise. They always talk about bushings and other stuff when I get something rebuilt. I'm sure a phone call to that shop could be a wealth of information since they actually know what their talking about, lol. Could help you decide between purchasing a new one or rebuilding a current one. If its a reputable shop they should give you a worst case scenario price also.
I'd go have it remanufactured and. The crap coming off the rebuilt Autoprone, Flaken and what not is pure crap. The guys at your local generator shop can redo it and give it some umph. If the cold temps are sustained where you are maybe consider a block warmer to help take some of the load off the starter and wear off the engine.
You may well have already thought of this, but could it be the solenoid? I've had at least one, if not more, go out on every Ford I've ever owned. A cheap part, and an easy fix.
Yeah, I thought of that - but a solenoid is just a go/no go kind of part as far as failure goes?? I sure hope it's not the solenoid, or I will have spent 80 bucks fur nuttin', plus spending an hour or two under the truck. I have a new solenoid too, in my toolbox.
The usual parts that are replaced on a rebuilt starter (it depends greatly on the price, and who's rebuilding it): the 2 bushings, mebbe an end plate, the contact points kit, the starter drive....but only if the teeth are worn...and the brushes...PERIOD.
Rebuilts: The starters are taken apart, hot tanked, starter is re-assembled with the new parts listed above, and into a box it goes.
VERY rarely is a new armature, or field coil installed...usually the rebuilders have extra used parts on hand....just in case.
A lot of the el cheapo rebuilt starters use parts that are made in China = crap.
The solenoid is about an $11 item and if the contactor isn't being made, you will hear the solenoid click and no power will go to the starter. Take a jumper cable from the positive side of the battery and to the starter terminal on the solenoid and see if the starter spins.
I had a solenoid stick about 2 months ago and had to rip the battery cable out of it's terminal lug to stop cranking - even with key-in-hand!
