Thanks, I see this axle is supposed to be lubed for life, but i was planning on changing the rear end fluid at 24,000 miles. Good practice or wasting my money?
good to change fluid I think just did mine had 64,000 on it. mine uses the 75x140 synthic about 14.00 a quart take 3 quarts to fill.
all self perference.
I believe in preventative maintenance but that is a little premature unless you are experiencing problems. If you do change it don't forget the additive since you have the LS.
I recently read that during the first few miles you get break in wear particles in your rear end and the fluid should be changed early in the life of your truck. Because of this I wanted to change the fluid.
Any wear particles will stick to the magnet on the VSS. You can remove it and see it you have anything there. A small amount is normal at any given time.
