Axle ratio
Old Jul 11, 2014 | 03:01 PM
bradpowell3557's Avatar
bradpowell3557
Axle ratio
How can I determine axle ratio on my F350 4x4 7.3l 6 speed diesel truck?
The label on door frame is blank under the axle code.
Old Jul 11, 2014 | 03:42 PM
retiredsparky's Avatar
retiredsparky
Firmly set parking brake.
Jack up one side only of the rear axle.
Install jack stand.
Put transmission in neutral - do not start engine.
Mark driveline with light colored marker so you can see the mark from the rear wheel that is jacked up
Mark the tire of the rear wheel at a convenient spot.
Turn that tire until the driveline makes one complete revolution while counting the number of times you turn the tire.
The # of turns will be the axle ratio. Larry
Old Jul 11, 2014 | 05:43 PM
guitarpicr's Avatar
guitarpicr
You might be able to find it on the rear pumpkin. Should be a metal tag with numbers on it. Others will be along with the codes for you. This is the easiest way to tell - Mine was stamped 373L- L for limited slip diff
Old Jul 11, 2014 | 08:31 PM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
Install jack stand.
If you don't know if it is a limited slip, Block both front wheels, Jack up both rear wheels ( use jack stands ) and release the emergency brake.
Old Jul 11, 2014 | 08:38 PM
Dan V's Avatar
Dan V
Dually or SRW?
Old Jul 11, 2014 | 09:15 PM
Robert6401's Avatar
Robert6401
I think a simpler way would be to tell us what RPM you're running at 70mph. With that info, we can answer your question unless you're running really big tires or something
Old Jul 11, 2014 | 09:19 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
This will NOT give you the gear ratio.
Any time the tires on a "differential-ed" axle are turned at different speeds (in the aforementioned case, one completely stopped) the ratio of driveshaft:tire will be different than the actual ring and pinion ratio due to the side and spider gears rotating around one another. In some instances, the gear ratio from driveshaft to tire can be as high as 2:1 using the "one tire spinning" method.
Old Jul 11, 2014 | 09:54 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I say just check the axle... Its usually on a tag.
Old Jul 12, 2014 | 01:07 PM
retiredsparky
Cleatus, I accept your reality and stand humbly corrected! Larry
Old Jul 12, 2014 | 07:40 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Cleatus, I was thinking the same thing.
You can do this as long as both tires are off the ground and you spin the tires together while counting driveshaft rotations.
Old Jul 12, 2014 | 07:47 PM
Pikachu's Avatar
Pikachu
Or just mark the drive shaft and one tire and have someone watch from the side while you roll the truck forward.
Old Jul 13, 2014 | 11:13 AM
retiredsparky
Pikachu, you are the master! That is the easy way to do it. Plus you can easily crush those ************ computers that keep locking up. Larry
Old Jul 13, 2014 | 07:35 PM
truckeemtnfords
Yea, the computer or your or your buddy's head as you lay there trying to count revolutions. Maybe you can get an ex-wife or girlfriend to count for you.
Old Jul 15, 2014 | 08:04 AM
bradpowell3557
SRW, 70 mph running 2100 RPM 285/75/16 tires. I'll check the rear chunk. I am guessing 4.10 due to speed and RPM. I was thinking RPM's would not be that high with 3.73.
Old Jul 15, 2014 | 08:05 AM
bradpowell3557
PS
thanks for the feedback
