Well guys Ive finally gotten off my **** to clean up my shed/shop and Ive got a good many axle shafts laying around. I was wondering how you keep your shafts. Anything other than leaning up in the corner is fine with me. Ive got like 12 sets.
I don't think many people have that many axleshafts lying around! But if I did, I'd buy an overhead storage rack at home depot or something that mounts to your garage ceiling and can hold like 300 lbs. That would a few shafts. You could also mount some PVC to the wall and make some "holsters" to put them in.
What I have noticed from other people storing them is that they lay the shaft flat on a shelf and have the hub/flange laying over the edge of the shelf.
I just set mine on the flange, with the shaft pointing up. Over in a corner so they don't get knocked over. You really don't want to lay them on their side, or over time they can warp. I suppose a setup like rebocardo mentioned would work, as long as you're not setting it on just the flange and the other tip.
When I made shelves in my garage there was a 2' wide section at the end that I simply made a "cove" and my spare axle bits stand in there in the corner. Each axle (and other long items) is greased to prevent rust, wrapped in a hefty and duct taped, with a tag hanging off so 10 years from now I can figure out which axle is which without having to rip the hefty's off and get grease all over my clothes. I only have four or five however. A friend of mine has maybe 25 axle shafts and he hangs them from the ceiling in his shed, also covered in grease.
Thats a good idea putting them in plastic bags.
Any time I get even near my shelf with greasy u-joins, shocks, and shafts, grease happens to jump on me.
Recently checked on some parts, steering columns and related parts, stored outside in 55 gal. drum some 2 yrs. ago. Somewhat surprise to find there was no condensation or rust on the parts. Used the steel band, came with the drum, to seal the lid to drum. Would have to measure for length, perhaps if layed at an angle; although, may not be cost effective if limited to a couple items. Added couple of desiccant pads when I resealed the drum.
I put engine blocks in those "contractor grade" oversized home depot hefty bags. Keeps the oil/grease on the parts and keeps my shirts clean.
Just make sure when you tie the bag closed, you tag it so you know what it is without opening the bag thus defeating the purpose of this measure!
If a rack built suspended from ceiling isn't a option,a narrow floor to ceiling rack similar to a partition about 8 to 10 inches wide could be built pretty easy and lay axles horizontal facing outward
