Furnace issues
Old Jan 19, 2008 | 11:58 PM
ford2go's Avatar
ford2go
Furnace issues
It's been a bad Friday/Saturday. Friday night my nearly new furnace quit heating. Got the guy out, and he thought that it might be low propane pressure -- I was not real enthused about this because other stuff was working.
Anyway, I managed to keep marginally warm with my woodburner ( temp went to -15F outside -- I never went below 50). And, the furnace guy came back on Saturday and solved the problem with the help of the propane guy.
Was not really the pressure -- there was soot blocking the chamber between the chimney exhaust fan and the flame. This caused the flame to drift back somewhat and trip the overtemp switch -- which kept the whole mess from blowing up!
During the course of all this I learned that the propane inlet pressure was 9" -- and it was supposed to be 11". However, I also learned that the internal furnace regulator ( now replaced ) further cut this down to 5" - not supposed to do that.
I'm thinking that the internal regulator failed sometime after the furnace was installed in November. I think that this really low pressure caused the flame to generate soot and ultimately clog the system. I really don't know a lot about propane combustion, but this seems reasonable to me.
I'm wondering if anybody has any opinions on the cause. I have my theory, but as noted, I'm far from an expert.
Thanks,
ford2go
Old Jan 20, 2008 | 12:15 AM
VikingBabe's Avatar
VikingBabe
I only use propane heaters (old style using clays). But used to use old propane powered Servals fridges while living on a mining claim. You had to keep an eye on any soot buildup and clean the pipes for the flame to work properly.
Old Jan 20, 2008 | 10:34 AM
GLR's Avatar
GLR
Propane will generate soot, even though some gas guys say it won't. Sounds like there should be some warranty on that furnace. Did you have a power outage or surge? that won't help electronic controls. Good thing you had a back-up heat source.
Glowplugger
Mar 15, 2019 10:45 PM
ford2go
Jan 21, 2016 09:36 PM
ford2go
Oct 28, 2013 08:53 AM
just another truck
Dec 14, 2010 08:06 AM
50calmike
Feb 10, 2007 07:39 AM
