Sponsored by: Real Truck
stupid question about folding down back seat
Old Jan 19, 2008 | 05:35 PM
rcsjr4546's Avatar
rcsjr4546
2003 - F250 CC 4x4 - chipped and piped King Ranch.
Ok, here goes....I have owned this truck for about 3 months now and cannot figure out how the back seat folds down. I looked under the seat and do not see anything that would allow it to fold down. The original window stick indicates folding rear seat. Because it is a king ranch do they not fold down? The back only folds forward about 1ft or so, but not flat. Anyone else have this same issue?
Old Jan 19, 2008 | 05:43 PM
nubeee1's Avatar
nubeee1
Some thing sounds in the way. My 06 350 split rear seats both lay flat with the side activator.!!
Old Jan 19, 2008 | 07:04 PM
3000 FPS's Avatar
3000 FPS
On the crew cab the bottom part of the seat folds up and the back folds down. There are levers on the side of the seats for this. Separate levers for the bottom and the back.
Old Feb 23, 2008 | 09:42 PM
powerstroke6ltr's Avatar
powerstroke6ltr
05 and up had the flex fold 60/40 system....the earlier c/c's only had a fixed bottom cushion and partial folding back...
Old Feb 23, 2008 | 10:18 PM
misterc's Avatar
misterc
I have a 2004 and the seat back folds down flat. The lever is on the side(not easy to see).
Old Feb 23, 2008 | 10:22 PM
Kep4's Avatar
Kep4
Jäger
On my 05 CCSB the seat backs fold forward, but not 'flat' horizontal. The seat bottoms fold up nicely so you can access the metal frame thingy that very few of us ever use. The lever is on the side of the seat as stated above.
Old Feb 23, 2008 | 11:45 PM
tippmann87's Avatar
tippmann87
probably best for the superduty section, not the 6.0
Old Feb 24, 2008 | 01:18 AM
rollerstud98's Avatar
rollerstud98
in 04 the backs started folding flat, prior to that the backs only folded part way, also in 04 the bottoms started folding up
Old Feb 24, 2008 | 07:49 PM
oltrucker's Avatar
oltrucker
look upnear the side of the back rest and there is the little lever to tilt the seat back
Old Feb 25, 2008 | 12:38 PM
walleyeman's Avatar
walleyeman
This is the superduty section, or was this thread moved?
My 05, backs fold down flat. Lever is on the side at 1/2 way up the seat back.
Old Feb 25, 2008 | 03:25 PM
Cal Ntv's Avatar
Cal Ntv
It depends on whether your King Ranch has a bench seat or the Bucket Seats in the back. If you have the buckets in back they won't fold down. The bench seat will have the seat back fold down flat or the seat portion fold up with the fold out metal floor below.
Old Feb 25, 2008 | 03:52 PM
bgalaxy67's Avatar
bgalaxy67
I have an 03 and the back just tilts, Does anyone have one in those same years with a bench that folds flat?
I would sure like to swap mine to one that folds flat
Old Feb 25, 2008 | 06:35 PM
msgtg's Avatar
msgtg
I have an 03 King Ranch. The lever is almost hidden behind the seat belt/shoulder harness strap. On mine, the seat doesn't fold completely down...if you push on it, it'll go a little further but I really think these were designed to give us access to the behind the seat storage tray...the spare tire removal kit and storage area.
To my knowledge, my bottom bench doesn't fold anywhere...it doesn't move. If you really want a seat that folds completely down, you're gonna have to go find a different year model that's thinner (I wonder what the ride in the rear seat will be like with much less padding?) so that it can lay flat.
Joe
Old Feb 25, 2008 | 06:42 PM
aldridgec's Avatar
aldridgec
My 04 CC had the flex fold seat.
Old Feb 25, 2008 | 11:36 PM
powerstroke6ltr
oops my bad... I hadn't seen an 04 with that option... seems i was misinformed...sorry... I would like to know if the flexfold seats fit in the non flex fold trucks to...
