78 lighting problems
Old Jan 19, 2008 | 05:25 PM
78 Ranger's Avatar
78 Ranger
the lights on my 78 ranger started pulsating lately and then suddenly my low beams would not work at all. then as soon as i flashed my high beams one light come on. some times the light that won't come on will come on really dim. my brake lights also stopped work around the same time
thanks
Old Jan 19, 2008 | 08:31 PM
Franklin2's Avatar
Franklin2
With the headlights on, pull the floormat back on the driver's side, and check for voltage on the dimmer switch. One wire will be 12 volt from the headlight switch. The other two wires are highbeam and lowbeam. So when you switch the dimmer switch, you should have 12 volts on one, and then the other when the switch is activated. Check this out and see what you have, and also check out the plug to make sure it's not corroded.
If this checks out, I would check your grounds. Run a new ground wire from the battery negative to the bolt that holds the alternator regulator.
Old Jan 23, 2008 | 06:28 PM
78 Ranger's Avatar
78 Ranger
if an external voltage regulator is ruined will it work intermitantaly or not at all
Old Jan 23, 2008 | 09:46 PM
Franklin2's Avatar
Franklin2
If the voltage regulator has a poor ground, flickering lights (voltage variation) is a symptom.
toohott7718
General Automotive Discussion
Mar 3, 2015 09:47 PM
Rods 1977
Nov 18, 2012 10:43 PM
speleausmining
1983 - 2012 Ranger & B-Series
Feb 19, 2010 12:20 AM
rcw3023
Nov 2, 2007 11:24 AM
GrayRanger4x4
Electrical Systems/Wiring
May 29, 2006 11:48 AM
