Broken Shift Column
Old Jan 19, 2008 | 05:10 PM
64blue's Avatar
64blue
Broken Shift Column
I need to change this thing out, but I don't want to cut the harness. Any suggestions?
Old Jan 19, 2008 | 05:13 PM
Mil1ion's Avatar
Mil1ion
Tilt or non-tilt
Need more info
On Non-Tilt columns the wiring harness pulls through without cutting
or you just remove the connectors with a removal tool and rreinstall them again
Old Jan 19, 2008 | 05:15 PM
64blue's Avatar
64blue
[/img]
This is what it looks like right now
Old Jan 19, 2008 | 05:20 PM
64blue's Avatar
64blue
I looked at the harness end and it looks way too big to slide through. This is a non-tilt column
Old Jan 19, 2008 | 05:41 PM
Todds79's Avatar
Todds79
The bottom end connection is a U shape. In the middle of the U, from the bottom end is a piece of plastic that can be removed with a small screwdriver. Once this is removed, a pick can be used to move the small plastic tabs over, and the wires will pull out of the connector one at a time. Make a drawing of where the wires are located in the connector. Use the reverse for re-assembly. Have done many with just a very small screwdriver. No need to cut wires.
Old Jan 19, 2008 | 06:34 PM
Mil1ion's Avatar
Mil1ion
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
