Files for 400 for Dyno2003 ?
Old Jan 18, 2008 | 07:09 PM
ErrorS's Avatar
ErrorS
Just wondering if anyone has some or knows where to get them.. I just don't know enough to do it manually. I'd like to see curves for some of the more popular cams out there and against stock as well.
Plus I'm not sure if I'm doing the heads right?
All I can find on the internet are files for Windsors.
I'd appreciate it if anyone could help, thanks.
Old Jan 18, 2008 | 08:20 PM
danlee's Avatar
danlee
I have DD2K and Dyno Sim. What is the file extension for Dyno 2003?
Old Jan 19, 2008 | 07:00 AM
ErrorS's Avatar
ErrorS
".dyn" for engines, ".flw" and ".cam" , I think it's just a newer version of DD2k.
At the very least it would have the specs that I could turn around and type into Dyno2003.
My E-Mail address is errorsx AT gmail.com
Old Jan 19, 2008 | 10:39 AM
hollenjoe's Avatar
hollenjoe
I have dyno2003, and its pretty easy, cam specs com from manufacturers, scr is obvious and valves are 2.04 int and 1.66 ex, plus heads are stock and low performance, the rest is up to your set up....what else do you need ?
Old Jan 20, 2008 | 03:01 AM
ErrorS's Avatar
ErrorS
well, stock cam to compare. For intake do I do single plane standard flow? and what would something like a weiland or edelbrock intake be considered?
danlee, thanks for sending me the head and cam files, I'm gonna go play with them now.
Old Jan 20, 2008 | 06:27 AM
danlee's Avatar
danlee
A stock manifold would be a Dual Plane Standard Flow, while an Edelbrock or Weiand will be a Dual Plane High Flow. An Edelbrock RPM Air Gap manifold will be a Dual Plane Max Flow.
stpackard
Nebraska Chapter
Jan 4, 2016 01:06 PM
amdriven2liv
Testing.....
Sep 22, 2012 12:24 PM
kalsc
May 25, 2007 07:37 AM
TwelveAlpha
Oct 22, 2006 04:34 PM
ctch88
1978 - 1996 Big Bronco
Feb 28, 2006 01:21 AM
