I don't know what the what the purpose of the coolant to the TB is. If it is to keep the TB functional in cold climates, than it would help to disconnect the coolant here in Los Angeles.
As I understand it the ONLY reason the coolant it passed through the TB is to keep it from freezing. If it freezes into a given position while driving the drive will have a hard time stopping. It's one of those "better safe than sorry" band-aid features. Even though most uses don't need it, they did it to everyone just to save themselves from lawsuits I guess.
Your 100% correct. Up north your throttle body will or well can freeze open on the highway!
Removing the coolant from the TB might be something to try when the weather warms up in a couple of months.
Do our TBs have bearings or bushings around the valve flap? I would be more inclined to try it if our TBs had bearings. It is over $300 to buy a TB for our trucks with bearings.
We can't stick a thermocouple in the plenum so, we need another way.
To test this we could:
1) remove the coolant hoses
2) warm the engine
3) measure the ACT sensor with a DVM while idling, 1krpm, 2krpm, 3krpm
4) reconnect the hoses
5) measure the ACT sensor with a DVM while idling, 1krpm, 2krpm, 3krpm
6) compare the results!
For safety we should attach the leads to the ACT before the test and run them out over the fender and into the cab, read the DVM there while watching the tach.
