The shift lever on the column got really sloppy within the last week, it's hard to find reverse without putting it into neutral or park. Could this just be an adjustment or maybe a wore out bushing?
Fixed!!! Thank you Action4478!
Read your response, went out and took a peaky and sure as heck... thats what it was. It took longer to find my torx bits then it did to fix it.
WALJON, just lay on the floor and look up in there, it's as plain as day (at least with the flashlight) Just us a T-30 Torx bit
I want to go out now but its too cooold -23c tonight without the wind BRRRR
Holy crap my shifter has been driving me nuts since I got the truck 2 years ago never could find the problem I even replaced the shifter lever(mainly cause the OD broke off...its 30 deg out and I just ran out with a flashlight to look and ill be darn those bolts are backed out close to 3/4 of an inch...I will be fixing that tomorrow for sure...great find reps sent.
-------------Jeremy
-------------Jeremy
-------------Jeremy
c'mon jboard! it was 34 deg when I did it! just the excitment of fixing it injust a few minutes was good enough for me!! as for WALJON... we'll let you slide on this one for the night
Rick, thanks again for the info. I'll figure out the rep point thing for shortly!!!
