Sponsored by: Real Truck
Flashlight install
Old Jan 17, 2008 | 07:03 PM
tac53parsons's Avatar
tac53parsons
Question Flashlight install
I'm installing a Stinger flashlight charger in my 04 F250 FX4 Lariat Ext. cab. I plan on mounting it on the plastic sill plate beside the driver seat. It looks like the best place to get easy access. There is a bundle of wires under the sill plate that run to the driver seat. Anyone know which wire has got power with the ignition on?
Old Jan 17, 2008 | 08:30 PM
F350-6's Avatar
F350-6
There's usually a loose wire taped to the wiring bundle coming off the OBDII connector that is a fused key on wire. The loose taped end wires near the firewall just go through the firewall with blank wires on the other side.
Old Jan 19, 2008 | 12:33 AM
tac53parsons
Well I finished it. I found a wire that only gave me power with the key on so I don't kill the battery. I originally had it facing the other way but discovered the door wouldn't shut. I think it's a nice addition.
Old Jan 19, 2008 | 12:35 AM
greythorn3's Avatar
greythorn3
looks like it would fall out there... why no in the center hump?
Ray
Old Jan 19, 2008 | 12:41 AM
tac53parsons
My wife likes to sit there... It makes it easy to grab when you need it. The "claws" are spring loaded so it holds it in pretty snug. I was going to put it on the dash but the only flat spot I could find that wasn't in the way was under the cubby hole where the newer trucks have the upfitter switches. The only problem is my brake controller is already mounted there.
Old Jan 19, 2008 | 12:47 AM
greythorn3's Avatar
greythorn3
dont mount it to the airbags! hehehe
Ray
Old Jan 19, 2008 | 03:03 AM
GregsSD's Avatar
GregsSD
I've got a rechargable maglite in mine, works great and is easy to get to and I just tapped into a hot wire under the door sill for power:
Old Jan 19, 2008 | 06:39 AM
tac53parsons
Thats where I got my power. I was amazed when I pulled up the sill plate. You couldn't even see the wire bunddle. The whole thing was filled with sand.
Scalemandave
1997 - 2003 F150
May 21, 2011 11:00 PM
tac53parsons
Feb 1, 2009 11:45 AM
jaym69
2004 - 2008 F150
17
Jan 27, 2009 12:38 PM
HotLap
2004 - 2008 F150
36
Jun 23, 2005 03:29 PM
