'03 Excursion with 6.0. Just changed out injectors and two new batteries. Start truck (really hard to start) and it runs terrible rough.
The alternator is HOT (burning skin hot) within 30 sec of starting. Toasted the old Alternator, so a new one went in. Still gets huge hot right away. No drain when the truck is off (batteries stay charged), but the voltage drops FAST (charged batteries to 12V+ but they drop below 10V within seconds of starting) as soon as the truck is started.
Mechanic unhooked alternator completely from the system (the new one), and truck ran GREAT for about 30 seconds and then died. When the alternator is connected, it runs like crap.
Somewhere, we seem to be getting a huge power drain that is loading the alt and draining batteries very quickly, causing immediate injector problems from low voltage (this is the theory).
Help help help!!!!! I don't know where else for the mechanic to look??????
It is.. could be bad alternator even tho its new.. Did he test the alternator? For an electrical drain to be that drastic.. You'd practically have to cut the harness and wedge it on metal.. If its acting up that bad, thats a pretty nasty voltage flux..
Never ran across this type of problem.. Does the voltage remain above 12V on the batteries with the Alt plugged in?
I believe it does (when it's off). The minute it's started the batteries drop to 10 or less. He's going to pull the alt and check it, but wow that would be a freak thing (brand new bad alternator).
Wouldnt be the first time I've seen it.. Honestly I don't know what else in the electrical system would cause that big of a loss.. I assume the Battery Cables checked out good?
Yeah, the cables were cleaned and are perfect. What else is on the alternator 'circuit' that is seperate from the batteries (what would have been disabled when the alternator was unhooked)? It APPEARS that something on that circuit is killing the system. I just don't have a wiring diagram to trace it though.
