Ok, as stated in an earlier post I fixed the broken bolt in head of my 352 problem. then I put the rocker shaft on, and just tightened it till the shaft was flush with the head, but didnt torque them. Then I noticed that on the #1 cylinder, the pushrods were up higher, pushing both valves in too far. I replaced valves, pushrods, and lifters on this cylinder, but not the others, earlier. the pushrods are the same length, and I'm absolutly positive the lifters were too. I turned the engine some and this problem remained. Both these pushrods stuck out a little over 2 inches from the intake side where I measured from, while all other 6 pushrods measured a little under 2 inches. oh boy...
ANY ideas would be appreciated, I'm sure I ordered lifters for a 352 (from Macs auto parts)
Thanks for the help
Garrett
1965/67 352 & early 1968 360/390 = C4TZ-6565-B .. Pushrod = 9.62" long
Late 1968 & 1969/72 360/390 = C8AZ-6565-A .. Pushrod = 9.59" long.
Per side > >
2-C1AZ-6A527-A .. Rocker Arm Shaft Support Bolt = 3/8" -16 x 3 19/64"
6-C1DZ-6A527-C .. Rocker Arm Shaft Support Bolt = 3/8" -16 x 2 31/32"
Ford campaign fixum for 352 engines only.
AR) 372351-S .. Rocker Arm Support Stud = 3/8" -16-24 x 3 7/8" .. use in countersunk holes.
AR = as required.
