Sponsored by: Auxito
heater problem
Old Jan 16, 2008 | 07:29 PM
hammerhead3006's Avatar
hammerhead3006
heater problem
2003 F150 Lariat with no floor heat . Defrost works fine ,panel works fine but very little at the floor . Any answers?
Old Jan 16, 2008 | 08:25 PM
firstonraceday's Avatar
firstonraceday
Could be a problem with the vacuum supply to the blend door. However, you'd probably get better answers in the 1997 - 2003 forum which is a couple of forums down the page.
And welcome to
Old Jan 16, 2008 | 09:09 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from '09 F150.
Welcome and thanks for joining us at FTE!
Old Jan 17, 2008 | 10:34 AM
KingRanchMan02's Avatar
KingRanchMan02
Sounds like a possible broken blend door. Do you have manual heater controls or EATC? Good luck!
Old Jan 17, 2008 | 02:35 PM
hammerhead3006
EATC I talked to a Ford tech today . He seemed to think maybe a pencil or somthing got down in there and won't allow the door to work . He said if it is broken I have to pull steering column and dash out to fix it
'90-f150-302-5spd
Apr 9, 2010 05:22 AM
mooncricket
Jun 14, 2007 01:10 PM
zman764
1997 - 2003 F150
Nov 26, 2004 02:00 PM
fogerson
Garage & Workshop
26
Oct 21, 2004 01:02 AM
