Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Need a new floor jack
Old Sep 29, 2004 | 07:41 PM
fogerson's Avatar
fogerson
I currently have a small portable sears floor jack and it works fine but i want something bigger like more in the range of 3000 pounds. My question is what kind to buy and from where thanks for the advice
Old Sep 29, 2004 | 07:58 PM
91f250460's Avatar
91f250460
Some people will probably argue with me, but I bought mine from Sam's club over 10 years ago and am still using it almost daily. Best 70 bucks I think I ever spent. Of course I always use jack stands before crawling under any vehicle.
T. Roberts
UFD Local 1147
Old Sep 29, 2004 | 08:07 PM
fogerson's Avatar
fogerson
I saw one supposedly made by michelin out at sams and I wondered how it held up because I dont want something to fail thanks
Old Sep 30, 2004 | 02:57 PM
nick88f150's Avatar
nick88f150
i just bought one at lowes actually, i never even knew they had em. Ours finally bit the dust after years and years of use. The new one is a Kobalt, I'm trying to think of what it can lift (I'm at school so i cant go check), but it ran abt 50 bucks. I've used it a couple times and it lifts pretty well. However, if you have a lifted truck, or a bigger truck at all, I'd find something else, I have a stock F150 and it barely lifted it off it's tires. I had to block up the jack to raise it enough to get stands under it. It's got like 16" of lift.
Old Sep 30, 2004 | 09:23 PM
Beechkid's Avatar
Beechkid
Floor Jack
My 1.5 ton Sears floor jack that is 25 years old was getting a little tired. Now I'm not a Pep Boys fan by any means but, I bought a Torin 3 ton floor jack from them for $50...they now have them with a $10 rebate from Torin (which is assembled in Long Beach, Ca). It is a very stable jack, single piston type which picks up my F150 or the Wifes 4500 lb car with no problem. They also make a twin piston 3.5 ton jack which PB sells for $69. The twin unit is much easier to use but the single piston works fine for me......First time in my life I ever recommended anything from PB.
Old Sep 30, 2004 | 10:30 PM
hdgapeach's Avatar
hdgapeach
I was in Sears this past weekend and they had their ton and a half floor jack with two jack stands, a fender cover, cheezy wheel chocks, and roll around seat for less than $100. It was all Craftsman (not the "Champion" brand).
Old Sep 30, 2004 | 10:41 PM
Sberry27's Avatar
Sberry27
My bud bought one from Northern or Harb frt, a long reach 5 ton rated for about 230$, maybe a little less. Its really nice and he works on a lot of pickups. Its a China junker but it works well for work in this range. I doubt a home shop would ever wear it out. I think he is on about the second one in 10 yrs,, but he uses it several times a day 24/7
Old Oct 1, 2004 | 12:29 AM
seventy2002's Avatar
seventy2002
Got Mine at Costco
A good deal at $70. I've seen the same model in use at the garage that services the company cars.
Old Oct 4, 2004 | 09:41 PM
Wooditude's Avatar
Wooditude
Just got a 3 ton Craftsman
Sears just ran a one day sale - 3 ton jack and a pair of jack stands for $60. Couldn't pass that one up. Lift's the entire front of my lifted F-250 off the ground great. Keep your eyes open, they'll be running similar sales again soon with the holidays coming up...
Old Oct 5, 2004 | 08:03 AM
FarmLaw's Avatar
FarmLaw
I second the Sams Jack. They sell it as a Michelin jack sometimes, and sometimes not; either way, it is the same jack. It works pretty darn well. They used to sell a version with a foot pedal for quick raising, which was also a nice jack. The newer jack has a 2 stage pump so it raises up with no resistance quickly on the high volume side, and then switches to the high-pressure pressure side when you start meeting resistance.
Old Oct 9, 2004 | 10:08 AM
gman88's Avatar
gman88
I also have the Michelin jack from Sam's. It works great, no problems lifting the Bronco and the two stage pump is awesome. I think it was around $59.00, no problems after two years.
Old Oct 9, 2004 | 07:57 PM
Violjohn78's Avatar
Violjohn78
I bought the Kobalt one at lowes.. goes up to 19 13/16" like it paid bout 90 for it. relatively easily plus it's wide and don't have to worry about it flexing at all. thing's prob 70 lbs at least. And it rolls on grass relatively easily (yes am not blessed with a real driveway or garage, but it works) have no problems getting under my truck or escort. plus got MORE stands with it. (4 pair now)
Old Oct 10, 2004 | 12:55 AM
nick88f150's Avatar
nick88f150
I must have the smaller sibling of your Kobalt. Mine's only about 25-30 pounds. But I do like their stands, I bought a pair of those too (came seperate). It does roll nice in grass tho, not too bad in stone either, I too have no real driveway.
Old Oct 10, 2004 | 10:46 PM
1982fordf100's Avatar
1982fordf100
In our garage we have a 3 1/2 ton craftsman floor jack. It came with two 3 1/2 jack stands. Its a really nice floor jack, it lifts to the frame in one pump of the handle. Plus it has a really big dish so you get a large contact spot on the frame. I carry a small 2 1/4 ton floor jack behind my seat in my 95 F150, which is soo much better than those scissor or and bottle jacks when changing a tire along side the road.
Old Oct 11, 2004 | 06:45 AM
Ian F's Avatar
Ian F
I have a couple of consumer jacks and I'm about ready to drop the coin for a more commercial version.
First jack was a $70 2.25t model from Pep Boys purchased back in '90. A few years ago, the seal blew out so and I didn't feel it was worth fixing, so I bought a 2.5t jack from Sears. Isn't bad and I still have it, but it's too tall to fit under the other-half's BMW M3 and MINI Cooper S, so I bought one of those aluminum 1.5t jacks from Sam's for $130 (over a year ago - can be found cheaper now). Not a bad jack, but it stuggles with lifting each end of our recently purchased Volvo P1800.
My biggest concern is not how well the jack lifts the car, but how controlled the valve is when lowering it. With the race-jack, the valve is a bit too "on-off" if you know what I mean. This makes it tough to lower the car a bit at a time to check stand placement.
