Sponsored by: Real Truck
Disabling Daytime Running Lights
Old Jan 16, 2008 | 09:49 AM
jetmagnum's Avatar
jetmagnum
On My Buddy's 06 F350 He Has Daytime Running Lights. Is There Any Way To Disable This Feature And Default Back To The Regular Headlight Switch Operation??
Old Jan 16, 2008 | 12:18 PM
nosebreaker's Avatar
nosebreaker
Don't take my word for it, but I think there is either a different relay near the switch you can put in or a 2nd wire that goes to the headlights for DTR.
Old Jan 16, 2008 | 02:56 PM
mkalck's Avatar
mkalck
If its anything like my '01...This is what I did...VERY simple...
Behind the drivers headlight mounted to the rail there is a resistor bolted to the rail. its protected by a metal shroud with holes in it...looks like a heatsink. Simply remove the electrical connection to that resistor...done If you ever want them back, just reattach.
Old Jan 17, 2008 | 06:53 AM
jetmagnum's Avatar
jetmagnum
Actually Sorry Guys, Your Both Wrong. This Vehicle Had A Fuse In The Underhood Panel At Position 13 Dedicated For The Daytime Running Lights. Get This, -----just Take The Fuse Out..........
Old Jan 17, 2008 | 08:20 AM
whjco's Avatar
whjco
Gee, I modified my fog lights so they would work as daytime running lights. I've found that folks are a lot less likely to pull out in front of me when they're on. I wish that my Excursion had come with them.
Old Jan 17, 2008 | 09:17 AM
redford's Avatar
redford
FTE Leadership Emeritus
I leave my lights in AUTO, fog lights on and I covered up the light sensor on the dashborad, so my headlights and fog lights are always on.
Old Jan 17, 2008 | 09:51 AM
mkalck's Avatar
mkalck
Cool...My DRL fuse on the '01 is tied in with other important things...I think it the horn or some other important lights, like brakes or turn signals.
Glad you tracked it down.
Old May 19, 2023 | 08:39 AM
Slytech's Avatar
Slytech
1st Gear
was the 3 fuse under the hood on my 06 e350 but it also operates the A/C clutch
Old May 19, 2023 | 10:21 AM
5851a's Avatar
5851a
This is a very old post. There is also a special section for vans. Welcome to FTE.
capt fantastikk
Jan 10, 2023 06:36 PM
BeerCan500
Nov 26, 2012 03:49 PM
mctim64
Nov 6, 2012 05:14 PM
Midnite1987
Jan 29, 2012 07:32 PM
hombrerana
Mar 2, 2004 10:59 PM
