6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
DPF smoke
Old Jan 16, 2008 | 08:34 AM
Larry NCKS's Avatar
Larry NCKS
DPF smoke
Hi everyone,
I just was referred to this site. I have an '08 6.4 stroker that at 17,000 miles has developed a huge smoking problem at the beginning of the DPF regeneration cycle. It smokes like a house afire for about 15 or 20 seconds. My dealer just shrugs his shoulders. I know others are having this problem also at various mileages. This is very obnoxious to drivers following when it happens.
Has anyone heard of a fix for this? I can't imagine it being anywhere other than the DPF itself or the computer. Thanks!
Larry
Old Jan 16, 2008 | 08:48 AM
Buckarcher's Avatar
Buckarcher
Originally Posted by Larry NCKS
Hi everyone,
Larry
The only fix I know of is for the outside temperature to warm up. If the exhaust system is cold when it starts you will get that until the extra fuel burns and warms it to the point of a better burn. At least that is the way I've heard it.
Old Jan 16, 2008 | 08:54 AM
Larry NCKS's Avatar
Larry NCKS
Thanks. Mine just started doing this. But both times it's done it, I had driven it at least 50 miles before it happened. The exhaust system had to be at normal operating temperature when it happened.
Larry
Old Jan 16, 2008 | 10:17 AM
dascro's Avatar
dascro
What color is the smoke. Blue means it is overloaded with fuel, black means the DPF is cracked. They absorb water so if it is cold then you will get white smoke which is just the water buring off.
Old Jan 16, 2008 | 10:37 AM
rob_nc's Avatar
rob_nc
Larry
Unless those 50 miles were loaded, it wouldn't matter. The DOC needs to be at least 600F before all additional fuel is burned. The white smoke is vaporized fuel. Ford needs to adjust the rate of initial injection so it doesn't overload the DOC.
Old Jan 16, 2008 | 10:54 AM
dascro's Avatar
dascro
Correct but the fuel burns off as a bluish smoke. These things hold an amazing amount of water. Either blue or black smoke is a problem. If it is just white smoke (steam) for the first 30 seconds or so then it is water and completley normal in cooler weather. I recently left a job with a large american truck manufacturer where I was a performance engineer. I came here out of boredom to help out so I am not 100% sure of what you may be seeing. If it is a blueish smoke, and fuel is burning off, then ford needs to fix this problem asap or DOC degradation will occur much sooner than anticipated
Old Jan 16, 2008 | 11:21 AM
Buckarcher's Avatar
Buckarcher
The smoke is white in the scenario he is talking about unless his is having an actual problem. Mine does it and I've seen others doing it too. Big billows of white smoke for a mile plus or minus in city traffic conditions. Mostly under acceleration, once up to speed it is still there but in much smaller quantity.
I've always just assumed it was water and fuel burning off together. Was a bit scary the first time I saw it though. Has done it 3 or 4 times total now.
Old Jan 16, 2008 | 12:08 PM
Larry NCKS's Avatar
Larry NCKS
Mine is blue smoke.
Old Jan 16, 2008 | 12:26 PM
dascro's Avatar
dascro
Well then with blue smoke I would take it to the dealer now. That is very bad for the DOC, DPF and fuel economy. Unfortunatly i have found that most dealers do not have a solid understanding of the new emissions systems. Either way, keep taking it to dealers until it is resolved. You do not want to drive it like this as the overfueling will cause the DOC to degrade faster than usual or even plug.
Old Jan 16, 2008 | 12:57 PM
SANDDEMON08's Avatar
SANDDEMON08
Mine is blue smoke.
Welcome to FTE, Sounds like you have a out of the ordinary problem and a good dealer should be able to address it. You may have a DPF issue or an injector issue. What is the build date of your truck.
Old Jan 16, 2008 | 01:07 PM
hammer toe's Avatar
hammer toe
have you checked your oil level?
Old Jan 16, 2008 | 01:33 PM
Larry NCKS's Avatar
Larry NCKS
Explain DOC please. That's a new one on me. Thanks!
Old Jan 16, 2008 | 01:36 PM
Larry NCKS's Avatar
Larry NCKS
Thanks. Without going out through the blizzard to the shed to look, I believe it's early April of 07. Does that make a difference?
Old Jan 16, 2008 | 01:48 PM
richfaa's Avatar
richfaa
Run your finger around teh inside of your tail pipe (when it is cold) If it is black or you can see black soot in the tailpipe you have a defective DPF causing your problem.
Old Jan 16, 2008 | 02:27 PM
rob_nc's Avatar
rob_nc
DOC = Diesel Oxidation Catalyst. This is the part of the dpf that reacts (exotherm) with the hydrocarbons (fuel) that are injected and creates the heat needed to oxidize carbon (soot).
phantomphixer
Apr 4, 2015 01:21 PM
Barbender
22
Feb 8, 2008 11:04 PM
btoohey44
Jul 10, 2007 10:42 PM
arkansas_bob
Aug 30, 2005 01:22 AM
TheDuke
Jul 25, 2005 08:04 PM
